notstock Posted May 20, 2011 Report Share Posted May 20, 2011 Great kit but my tires (2008 GT-500, stock wheels and tires) rub against the ducting when getting towards full lock. I don't see a problem so long as i remember to watch it. I have Steeda's adjustable front sway bar, and apparently the difference in diameter from the stock one makes the difference. The only way i see to correct this completely is to have smaller diameter ducting, as i see no other way to route it. Anyone else had or heard of this issue? I missing something? Quote Link to comment Share on other sites More sharing options...
SGT/SC#0471 Posted May 20, 2011 Report Share Posted May 20, 2011 Don't know your car, but I know when I fit the FRPP kit to mine car was up high on stands and I had a friend turning lock to lock looked good before he did this, but rubbed....then I got serious with the zip tie tension and some rerouting, new zip ties and now it works great....close but no rub with 275/19 fronts and the FRPP sway bar...kinda kooky how tight they are zipped in but man its much better looking and working than my first attempt...having someone turning lock to lock inside the car while you are under it was essential for mine to get fitted... Hope this helps.... Quote Link to comment Share on other sites More sharing options...
gth0007 Posted May 20, 2011 Report Share Posted May 20, 2011 Don't know your car, but I know when I fit the FRPP kit to mine car was up high on stands and I had a friend turning lock to lock looked good before he did this, but rubbed....then I got serious with the zip tie tension and some rerouting, new zip ties and now it works great....close but no rub with 275/19 fronts and the FRPP sway bar...kinda kooky how tight they are zipped in but man its much better looking and working than my first attempt...having someone turning lock to lock inside the car while you are under it was essential for mine to get fitted... Hope this helps.... I had the same experience. The routing of the flexible duct work has to be perfect and firmly zip tied into place to avoid rubbing with any size tires. There's just not much room in there. My SGT has the FRPP kit slightly modified to fit my standard size brakes and my Shelby lower grill brake duct / fog light set up. regards, Larry Quote Link to comment Share on other sites More sharing options...
notstock Posted May 20, 2011 Author Report Share Posted May 20, 2011 Thanks guys, having someone do the full lock while doing it makes good sense. I'll check it out. Quote Link to comment Share on other sites More sharing options...
SGT/SC#0471 Posted May 21, 2011 Report Share Posted May 21, 2011 I posted a thread about this with a few pics for you.... http://www.teamshelby.com/forums/index.php?/topic/67604-frpp-brake-cooling-kit-installed-pics/page__gopid__1158808 Cheers! Quote Link to comment Share on other sites More sharing options...
parshal Posted May 26, 2011 Report Share Posted May 26, 2011 My FRPP kit rubs a little, too, but it's too late for me to re-run it since I already cut the ducting! Quote Link to comment Share on other sites More sharing options...
