NMAv Posted May 18, 2011 Report Share Posted May 18, 2011 I ordered a J&M UCA from VMP per Justin's recommendation. I'm just now getting around to installing it, or so I thought. When I went to remot ethe original one I immediately noticed that the 2011 UCA bolt is much bigger than the one in the installation directions. Further investigation confirmed this as both true and a documented issue. It appears that I need a larger bolt adapter (circumference) in order to accomodate the existing bracket size. Alternately, I could get a bracket from a 2010 and install that, then the UCA. I'm not sure if there is a larger adapter available. What hae other 2011 owners done? Link to comment Share on other sites More sharing options...
ad445 Posted May 18, 2011 Report Share Posted May 18, 2011 I don't think it will work on 2011 gt500. the bracket is different then older models. BMR sells 2011 gt500 uca and a bracket to make it work. Link to comment Share on other sites More sharing options...
2010KonaBlueGT Posted May 19, 2011 Report Share Posted May 19, 2011 I don't think it will work on 2011 gt500. the bracket is different then older models. BMR sells 2011 gt500 uca and a bracket to make it work. I noticed Roush has a different part number for the 2011 vs. the 2010 and earlier too. Apparently, something has changed on the '11+ that requires a different part than earlier models. Phill Link to comment Share on other sites More sharing options...
NMAv Posted May 20, 2011 Author Report Share Posted May 20, 2011 I noticed Roush has a different part number for the 2011 vs. the 2010 and earlier too. Apparently, something has changed on the '11+ that requires a different part than earlier models. Phill Heard from Brad and J&M, they are hoping to have a 2011 version ready in the next 3-4 months. Link to comment Share on other sites More sharing options...
