JWok Posted May 16, 2011 Report Share Posted May 16, 2011 (edited) Does anyone know how to remove the factory installed shift knob on my 2011 GT500? I recently purchased an aluminum shift knob and I don't want to use heat or a wrench to remove the existing one. Edited May 16, 2011 by JWok Quote Link to comment Share on other sites More sharing options...
ChrisSD Posted May 16, 2011 Report Share Posted May 16, 2011 Strap wrench. Quote Link to comment Share on other sites More sharing options...
Ezareth Posted May 16, 2011 Report Share Posted May 16, 2011 I would advise against an aluminum knob. I bought a high quality aluminum Shift knob for my saleen and ended up noticing aluminum rubbing off on my hands after a couple of weeks. I ended up going back to the leather shifter. Quote Link to comment Share on other sites More sharing options...
nickD Posted May 16, 2011 Report Share Posted May 16, 2011 heat gun and strap wrench, FORD in all their wisdom decided to loc-tite the shift knob on the 2010-12s Quote Link to comment Share on other sites More sharing options...
JWok Posted May 18, 2011 Author Report Share Posted May 18, 2011 Thanks everyone for the help. Quote Link to comment Share on other sites More sharing options...
2010KonaBlueGT Posted May 18, 2011 Report Share Posted May 18, 2011 Does anyone know how to remove the factory installed shift knob on my 2011 GT500? I recently purchased an aluminum shift knob and I don't want to use heat or a wrench to remove the existing one. I removed mine without heat or a strap wrench. It's pretty easy but more complicated than heat/strap wrench. Pop the center console section by grabbing the back end and pulling up on it. Reach under it and remove the two bolts from the passenger side that hold the shift lever to the shifter base. disconnect all of the connectors and pull the console out with the shifter OR; From the underside, unsnap the leather cover and pull the shift lever w/knob and leather boot out. Put two pieces of fairly soft (such as pine) wood in the jaws of a vice and clamp the shifter knob between the wood (you can get it TIGHT with the wood jaw protectors). With a cresent wrench on the "flat" area where the two bolts go through (remove the rubber bushing and metal surround) unscrew the shift lever from the knob. Reverse the proceedure to replace the knob. HTH, Phill Quote Link to comment Share on other sites More sharing options...
