speedyburd33 Posted May 14, 2011 Report Share Posted May 14, 2011 (edited) hello all! I have gotten my whole grill and housing out of my SGT to put in my new SGT grill housing. The holes and support posts on the new housing don't line up and the grill doesn't fit inside the housing either. I have already scrached up the new housing trying to get it to fit properly. I am so frustrated right now. Also there is no hardware with the new housing...am I supposed to just use the old stuff? That doesn't look like a good idea. Do you think I got a bad grill housing or is there some trick to getting this to fit? Just like 99% of the rest of the parts from the Shelby Store, this didn't come with any instructions either. I have searched everywhere on the forums already...I thougth I saw a thread about this somewhere but I can't find it now... any help is welcomed...Thank you! :angry2: :angry2: :angry2: :mad: :mad: :mad: Edited May 14, 2011 by speedyburd33 Quote Link to comment Share on other sites More sharing options...
2007_Shelby_GT Posted May 14, 2011 Report Share Posted May 14, 2011 Check PM's for pics! Sam Quote Link to comment Share on other sites More sharing options...
socalwrench Posted May 14, 2011 Report Share Posted May 14, 2011 So, you took out the grille insert off of the old housing, which was a cut up GT grille, right? I know SAI did this to many of the first cars. And, you were trying to put the old insert into the new housing, right? The posts should line up. However, I found that the new housings are a very tight fit into the bumper opening. Compare the two pictures. The black one has the old housing, while the orange one has the new housing. Quote Link to comment Share on other sites More sharing options...
07SGT Posted May 15, 2011 Report Share Posted May 15, 2011 So, you took out the grille insert off of the old housing, which was a cut up GT grille, right? I know SAI did this to many of the first cars. And, you were trying to put the old insert into the new housing, right? The posts should line up. However, I found that the new housings are a very tight fit into the bumper opening. Compare the two pictures. The black one has the old housing, while the orange one has the new housing. Tell us about the lower driving lights.on the orange SGT Quote Link to comment Share on other sites More sharing options...
socalwrench Posted May 15, 2011 Report Share Posted May 15, 2011 Not really sure about the lower lights. They appear to be aftermarket ones mounted to the inside of the lower lip. Quote Link to comment Share on other sites More sharing options...
Glenn Greenwell Posted May 15, 2011 Report Share Posted May 15, 2011 Not really sure about the lower lights. They appear to be aftermarket ones mounted to the inside of the lower lip. Driving lights were interesting.... GG Quote Link to comment Share on other sites More sharing options...
Lgs ShelbyGT Posted May 15, 2011 Report Share Posted May 15, 2011 (edited) Same issues with the SPP grill insert I purchased a couple of month ago I asked for assistance from SPP and did receive 3 emails each from a different person. One sent me a hardware kit which is 4 small ready rods with 4 nuts, other than being longer these were no different than what was already installed. Really no useful help from SPP so took it on my own: First I used a silver sharpie to mark where the holes should be aligned Next I used a small die grinder bit along with a small round file (like used to sharpen chain saws) to elongate the holes My goal was to reshape the holes so that the bases where the ready rods attach to the billet grill would fit into the plastic SPP insert However, there wasn't enough material available on the plastic insert to accomplish this So I settled for removing enough material so that the 4 ready rods would fit into the grill insert Given the mounting holes were now larger than the star washers on the nuts, I picked up some small stainless steel washers. Ended up using 2 per hole with 1 between the grill & the insert to keep everything at the same spacing and 1 between insert & the star washer / nut Finally I used black zip ties to snug the insert to the grill, a couple in the center and 1 on each end Kind of Rube Goldberg approach, but in the end it turned out ok I'm just disappointed that the fit & finish was poor direct from SPP Added a couple of pics of fitment issues before my mods My link My link Edited May 16, 2011 by Lgs ShelbyGT Quote Link to comment Share on other sites More sharing options...
GRAYPNY Posted May 15, 2011 Report Share Posted May 15, 2011 (edited) If you had the old grille with the cutup stock grille behind the billet grille be sure and remove the whole thing. There should be tabs in fascia where the new surround will snap in. After that you can insert the new billet grille that goes with the surround piece and you should be good to go. Edited May 15, 2011 by GRAYPNY Quote Link to comment Share on other sites More sharing options...
socalwrench Posted May 15, 2011 Report Share Posted May 15, 2011 GrayPny, is right about removing the old housing from the bumper. However, I usually mount the grille insert into the housing before mounting the whole unit into the bumper. Quote Link to comment Share on other sites More sharing options...
SWEDEMAN Posted May 17, 2011 Report Share Posted May 17, 2011 Does the fitament really surprise you? I think they are Chinese made, so....................... Quote Link to comment Share on other sites More sharing options...
speedyburd33 Posted May 17, 2011 Author Report Share Posted May 17, 2011 I did have everything removed. the problem wasn't with the new housing fitting. It's with the stock SGT billet grill fitting inside the new housing all together. SPP is sending me another one to try. Hopefully this weekend will be better. Quote Link to comment Share on other sites More sharing options...
socalwrench Posted May 17, 2011 Report Share Posted May 17, 2011 I have an extra one laying around if you want it. Quote Link to comment Share on other sites More sharing options...
