tomhoulihan Posted May 7, 2011 Report Share Posted May 7, 2011 Has anyone had any experience with this kit? There is a new idler arm included and for the life of me I can't figure out where it goes, or how to install it? Any tips would be greatly appreciated. Thanks. Tom Link to comment Share on other sites More sharing options...
Secondo Posted May 11, 2011 Report Share Posted May 11, 2011 Has anyone had any experience with this kit? There is a new idler arm included and for the life of me I can't figure out where it goes, or how to install it? Any tips would be greatly appreciated. Thanks. Tom Locate the 3 bolts slightly to the left and below the supercharger pulley. You will see where the idler arm bracket goes by the orientation of the 3 bracket bolt holes. Install the idler arm there with the new, longer supplied bolts in the kit. If you still can't install it, let me know and I'll take a picture of mine for you. Link to comment Share on other sites More sharing options...
tomhoulihan Posted May 11, 2011 Author Report Share Posted May 11, 2011 Locate the 3 bolts slightly to the left and below the supercharger pulley. You will see where the idler arm bracket goes by the orientation of the 3 bracket bolt holes. Install the idler arm there with the new, longer supplied bolts in the kit. If you still can't install it, let me know and I'll take a picture of mine for you. I found a picture that helped me out immensely, I was lost. The stage 2 kit is now installed and I am VERY happy with the results !! -Tom Link to comment Share on other sites More sharing options...
