JBMB Posted April 22, 2011 Report Share Posted April 22, 2011 Have you ever had any problems with your convert frame? My passenger side raises slower than driver side for the first 12 inches of raising. A vert roof specialist told me it's a common problem with mid 2000"s Mustangs. I'm told a bar is bending under the tension of raising and may kink soon. He recommends welding on a supporting metal piece to strengthen the frame part which are bending and may snap off soon. See .pdf doc I have attached of the issue as it was a recall a while back. Thanks for your input. tsb05_24_06.pdf tsb05_24_06.pdf Link to comment Share on other sites More sharing options...
