Shelbyville Posted April 21, 2011 Report Share Posted April 21, 2011 Those of you who have painted your calipers - did you powdercoat or use caliper paint? Are you satisfied with the results? How did you handle the Brembo logo? And last - what did you do if anything with the fugly rears? Link to comment Share on other sites More sharing options...
kgillespie06 Posted April 22, 2011 Report Share Posted April 22, 2011 MGP makes rear caliper cover kits for the GT500. http://www.calipercovers.com/_e/dept/01-023/2005_2011_Mustang_GT_500_Shelby_.htm I ordered a set from CJ Pony Parts that I will install when I install my Baer Eradispeed+2 set up. Link to comment Share on other sites More sharing options...
fcettner Posted April 22, 2011 Report Share Posted April 22, 2011 When you install the Baer Eradispeed+2 set up make sure you have sufficent clearence inside your wheel and wheel balancing wieghts. See my write up below attached. Rear Caliper cover install.doc Rear Caliper cover install.doc Link to comment Share on other sites More sharing options...
kgillespie06 Posted April 22, 2011 Report Share Posted April 22, 2011 I have 19" wheels (2010) so maybe I will not need to do much to ensure sufficient clearance, but I will definitely check. Thanks for the heads up. Link to comment Share on other sites More sharing options...
blkGT500nCA Posted April 23, 2011 Report Share Posted April 23, 2011 Powder coat them. Do the rears too if you want them to match. Who ever coats them will need to get a decal made for the Brembo logo. They can either use the decal as a mask, or you could lay down your color, lay the decal, then clear over it. PM me if you've got any questions about powder coating. Link to comment Share on other sites More sharing options...
