10SHELBY Posted April 12, 2011 Report Share Posted April 12, 2011 (edited) I installed my signed airbag cover in my 2010 GT500 with electronics package. It took a while to figure things out but below is a short write up with photos. Remember to take your time. I took me about an hour.This is what I did, use your best judgment!1. I unhooked both battery terminals.2. Remove the glove box cover. 4 screws located on the bottom and wiggle the glove box out.3. Unsnap the 2 rear plastic spring clips on the black module located below the air bag. I am not sure what this is however I think it may have something to do with the navigation package. Your car may or may not have it.4. Slide the module back to release it and let it hang out of your way. 5. Reach in and unplug the airbag.4. Remove the 2 bolts securing the airbag to the frame. 5. Push the 6 bottom clips holding the airbag cover inwards.6. Then push the sides inwards.7. The top is more difficult but it should come out with a little movement.8. Apply a little force from the inside and outside, slowly pull on the cover. It should come right out.9. Then set the cover and airbag cover on a soft surface so not to scratch it. Remove the airbag unit by prying the clips away from the cover.10. Once you reassemble the airbag in the cover it should pop right back into the dash. 11. Reattach the 2 bolts that hold the cover, connect the airbag wires.12. Slide the module in place and snap it back in place.13. Reattach the 4 screws on the glove box.14. Reattach the battery and that is it.I hope this helps. Once again look at what you are doing and take your time.Rudy Edited May 6, 2014 by 10SHELBY Quote Link to comment Share on other sites More sharing options...
Hpfisterer Posted April 13, 2011 Report Share Posted April 13, 2011 Thanks for this post. I may give it a try myself. Quote Link to comment Share on other sites More sharing options...
10SHELBY Posted April 13, 2011 Author Report Share Posted April 13, 2011 I used info I found here somewhere and it was for an earlier model. It did not work. Once I figured out I was trying to remove the wrong thing and got on track it was really easy. I am willing to talk to you voice prior to if needed. Rudy Quote Link to comment Share on other sites More sharing options...
Southshore cobra Posted April 13, 2011 Report Share Posted April 13, 2011 I hope this helps. Once again look at what you are doing and take your time. Rudy PS I now have a spare airbag cover for sale if anyone is interested, PM me. Thank you Rudy - this is just what I needed! Quote Link to comment Share on other sites More sharing options...
10SHELBY Posted April 13, 2011 Author Report Share Posted April 13, 2011 I hope this helps. Once again look at what you are doing and take your time. Rudy PS I now have a spare airbag cover for sale if anyone is interested, PM me. Thank you Rudy - this is just what I needed! No problem. Please let us know if you have that black module box also. I guess I could climb in there and get the name of it but... Anyway let us know if you find it there. Rudy Quote Link to comment Share on other sites More sharing options...
MMcGuirk Posted April 13, 2011 Report Share Posted April 13, 2011 I did my 350 last Thursday. The 2010 thru 2012 airbag covers are way easier to do than the previous generation ones I have done. Tons of room to get the airbag cover assembly out. Quote Link to comment Share on other sites More sharing options...
Burning Blue Star IV Posted April 13, 2011 Report Share Posted April 13, 2011 Nice write up of the process. Thanks. Quote Link to comment Share on other sites More sharing options...
jrcjr65 Posted April 14, 2011 Report Share Posted April 14, 2011 I installed my signed airbag cover in my 2010 GT500 with electronics package. It took a while to figure things out but below is a short write up with photos. Remember to take your time. I took me about an hour. This is what I did, use your best judgment! 1. I unhooked both battery terminals. 2. Remove the glove box cover. 4 screws located on the bottom and wiggle the glove box out. 3. Unsnap the 2 rear plastic spring clips on the black module located below the air bag. I am not sure what this is however I think it may have something to do with the navigation package. Your car may or may not have it. 4. Slide the module back to release it and let it hang out of your way. 5. Reach in and unplug the airbag. 4. Remove the 2 bolts securing the airbag to the frame. 5. Push the 6 bottom clips holding the airbag cover inwards. 6. Then push the sides inwards. 7. The top is more difficult but it should come out with a little movement. 8. Apply a little force from the inside and outside, slowly pull on the cover. It should come right out. 9. Then set the cover and airbag cover on a soft surface so not to scratch it. Remove the airbag unit by prying the clips away from the cover. 10. Once you reassemble the airbag in the cover it should pop right back into the dash. 11. Reattach the 2 bolts that hold the cover, connect the airbag wires. 12. Slide the module in place and snap it back in place. 13. Reattach the 4 screws on the glove box. 14. Reattach the battery and that is it. I hope this helps. Once again look at what you are doing and take your time. Rudy PS I now have a spare airbag cover for sale if anyone is interested, PM me. Good write-up. This will help quite a bit.. Thanks Quote Link to comment Share on other sites More sharing options...
Hpfisterer Posted April 15, 2011 Report Share Posted April 15, 2011 Do we have to disconnect battery? What are the risks if i dont. Quote Link to comment Share on other sites More sharing options...
10SHELBY Posted April 15, 2011 Author Report Share Posted April 15, 2011 Do we have to disconnect battery? What are the risks if i dont. Well there is a lot of power in that airbag and I think it is way safer to disconnect. I did both terminals because I did not want to take the chance. I just disconnected the terminals and laid a piece of rubber on top of the battery . Then I just let the terminals rest on the rubber. Good luck! Let us know who you did. Rudy Quote Link to comment Share on other sites More sharing options...
Hpfisterer Posted April 16, 2011 Report Share Posted April 16, 2011 Well there is a lot of power in that airbag and I think it is way safer to disconnect. I did both terminals because I did not want to take the chance. I just disconnected the terminals and laid a piece of rubber on top of the battery . Then I just let the terminals rest on the rubber. Good luck! Let us know who you did. Rudy Got it on. Only disconnected negative. The hardest part is prying off the cover and putting the new one on. Once I realized the plastic cover is pliable I was able to bend it slightly and it went off and back on pretty easy. Took me an hour as well. Your pics came in very handy. Thanks. The unique thing about the sigs is that each one is a bit different in some sort of way. Quote Link to comment Share on other sites More sharing options...
jmungiel Posted May 11, 2011 Report Share Posted May 11, 2011 where can you buy a new air bag cover? I would like to keep one original and have the other signed by mr. shelby. a link would be great. Thanks Quote Link to comment Share on other sites More sharing options...
1wickedgt500 Posted May 12, 2011 Report Share Posted May 12, 2011 Rudy, if the 10' air bag cover is the same as the 11' I'd be interested in your spare cover. Let me know what you want for it....Thanks Quote Link to comment Share on other sites More sharing options...
Madlock Posted May 13, 2011 Report Share Posted May 13, 2011 Thanks for the terrific write-up. Mine will be going-in shortly - after I figure some way of protecting its surface before installing. Quote Link to comment Share on other sites More sharing options...
nickD Posted July 22, 2011 Report Share Posted July 22, 2011 thanks for the write-up got my on in under 30 minutes with the instructions Quote Link to comment Share on other sites More sharing options...
nickD Posted July 22, 2011 Report Share Posted July 22, 2011 one thing to note, you definitely want to disconnect at least the negative terminal and you should wait at least 10 minutes for any residual charge to dissipate since you will be working right by the airbag if it were to go off, very dangerous!! Quote Link to comment Share on other sites More sharing options...
BlueByU Posted August 5, 2011 Report Share Posted August 5, 2011 (edited) I took my Air Bag Cover to my local Ford Dealer . They installed it in ( 10 )ten minutes WITHOUT pulling the battery. You may not want to pull the battery you may lose computer information. Everybody lover the Air Bag Cover. Edited August 11, 2011 by BlueByU Quote Link to comment Share on other sites More sharing options...
Amigo GT500 Posted August 10, 2011 Report Share Posted August 10, 2011 I received yesterday along with a picture of Mr. Shelby signing my air bag cover......I haven't installed yet. Quote Link to comment Share on other sites More sharing options...
txcobra Posted August 10, 2011 Report Share Posted August 10, 2011 That's awesome. I shipped mine off yesterday....can't wait to get it back! Quote Link to comment Share on other sites More sharing options...
Amigo GT500 Posted August 10, 2011 Report Share Posted August 10, 2011 That's awesome. I shipped mine off yesterday....can't wait to get it back! Mi amigo...you shuld receive it soon because mine took around three weeks. I had a small problem because the half top part came a little bit bent to the right side where the GT500 is written......but I think that it won't be noticeable when is installed....Also I am thinking to have engraved the VIN # on it. Be safe.... Quote Link to comment Share on other sites More sharing options...
Firekiller Posted August 11, 2011 Report Share Posted August 11, 2011 Do we have to disconnect battery? What are the risks if i dont. Well there is a lot of power in that airbag and I think it is way safer to disconnect. I did both terminals because I did not want to take the chance. I just disconnected the terminals and laid a piece of rubber on top of the battery . Then I just let the terminals rest on the rubber. Good luck! Let us know who you did. Rudy +10000 on waiting at least 10 minutes before removing airbag after battery disconnect. I have personally seen what these things can do and 10 minutes is a lot better than a hospital visit. Dont believe me here ya go watch this. Quote Link to comment Share on other sites More sharing options...
Amigo GT500 Posted August 14, 2011 Report Share Posted August 14, 2011 Thanks Rudy. Your instructions and explanation was very clear. I dd easily........ I applied a matte clear finish protector to old ma's signature. I don't want to take any risk to have it erased.. Quote Link to comment Share on other sites More sharing options...
fgrdods Posted August 19, 2011 Report Share Posted August 19, 2011 Rudy, Dash looks awesome. I'm thinking about doing it this winter. Hope to meet up at one of your club events to get a close-up. Tim Quote Link to comment Share on other sites More sharing options...
BlueByU Posted August 19, 2011 Report Share Posted August 19, 2011 (edited) Thanks Rudy. Your instructions and explanation was very clear. I dd easily........ I applied a matte clear finish protector to old ma's signature. I don't want to take any risk to have it erased.. Great looking dash. I am glad you joined the DASH club. Edited August 19, 2011 by BlueByU Quote Link to comment Share on other sites More sharing options...
txcobra Posted September 3, 2011 Report Share Posted September 3, 2011 Mine arrived today! :happy feet: Just in time to get it installed and enjoy it over the holiday weekend! Quote Link to comment Share on other sites More sharing options...
TeeJay Posted September 3, 2011 Report Share Posted September 3, 2011 Mine arrived today! :happy feet: Just in time to get it installed and enjoy it over the holiday weekend! Let's put that bad boy on!!!!!! Cars and coffee tomorrow? Quote Link to comment Share on other sites More sharing options...
txcobra Posted September 3, 2011 Report Share Posted September 3, 2011 Already did...but yes, I am definitely in for tomorrow! Quote Link to comment Share on other sites More sharing options...
10SHELBY Posted May 8, 2014 Author Report Share Posted May 8, 2014 I reestablished the image links that had expired. Everything should look good now. Rudy Quote Link to comment Share on other sites More sharing options...
JDrew Posted May 9, 2014 Report Share Posted May 9, 2014 I wish I could find an extra cover for a 12 to send off. So jealous of everyone's dash. Quote Link to comment Share on other sites More sharing options...
Madlock Posted May 9, 2014 Report Share Posted May 9, 2014 I wish I could find an extra cover for a 12 to send off. So jealous of everyone's dash. You always can just buy another. I pity the poor buggers who have CS autographs on their 11-12 covers - only to upgrade to a 13-14 later. I might consider just swapping out the rest of the aluminum dash trim to match. Quote Link to comment Share on other sites More sharing options...
