Deadly Venom Posted April 11, 2011 Report Share Posted April 11, 2011 My GT 500 is grinding when I put it in reverse!? It does not grind if I put it in first gear after I stop and then put it in reverse. Anybody else having this problem? Help! Link to comment Share on other sites More sharing options...
bull3441 Posted April 11, 2011 Report Share Posted April 11, 2011 try cycling 3-N-R. see if that helps. Link to comment Share on other sites More sharing options...
Deadly Venom Posted April 11, 2011 Author Report Share Posted April 11, 2011 try cycling 3-N-R. see if that helps. What should I expect? Link to comment Share on other sites More sharing options...
bull3441 Posted April 12, 2011 Report Share Posted April 12, 2011 see if it goes in reverse easier. Link to comment Share on other sites More sharing options...
idrathergolf Posted April 12, 2011 Report Share Posted April 12, 2011 My GT 500 is grinding when I put it in reverse!? It does not grind if I put it in first gear after I stop and then put it in reverse. Anybody else having this problem? Help! I have the same problem. It started when I had the TSB performed on the tranny. I have always put it into 4th first and then put it into R. The reason is that the pilot bearing is spinning and putting into 4th will stop the pilot bearing; no synchro in R, but the other gears have it. I kick myself for not having the dealer fix it right away. I just thought it would loosen up over time. It didn't. Now I just live with the problem. Link to comment Share on other sites More sharing options...
Slabo Posted April 12, 2011 Report Share Posted April 12, 2011 My GT 500 is grinding when I put it in reverse!? It does not grind if I put it in first gear after I stop and then put it in reverse. Anybody else having this problem? Help! That is because reverse does not have a synro. You have to line it up by shifting to first then reverse. It will become a habit. You are grinding because you are trying too hard to put it in reverse. Link to comment Share on other sites More sharing options...
stkjock Posted April 12, 2011 Report Share Posted April 12, 2011 That is because reverse does not have a synro. You have to line it up by shifting to first then reverse. It will become a habit. You are grinding because you are trying too hard to put it in reverse. /\ this. I have the same issue Link to comment Share on other sites More sharing options...
Curt A Posted April 12, 2011 Report Share Posted April 12, 2011 Flywheel warped, disc's dragging, and pressure plate not releasing. Time for another new clutch. Link to comment Share on other sites More sharing options...
Deadly Venom Posted April 19, 2011 Author Report Share Posted April 19, 2011 Thanks for the input guys. Curt A I have a new clutch and pressure plate, I don't think that is the problem. I did not know reverse does not have a syncro. I just did not remember it doing this untill recently. So there is no way to fix this? Link to comment Share on other sites More sharing options...
