stevedm Posted April 2, 2011 Report Share Posted April 2, 2011 (edited) Few things to go on this week. First up are a L&M 66mmTB and VMP plenum. I will port the blower myself. I want to point out the location of the Evap sensor on the 2011 models. You can see the difference in the plenums in the pictures below. I have a 3/8 inch hose and some clamps...in the end the sensor will be hanging or zip-tied somewhere and a 3/8 in hose will connect it to the new plenum. To continue my thread from yesterday here is the finished port and completed product. TR6 plugs are also in. Idles excellent. Runs great. Evap sensor relocation completed Cheers, hope everyone likes the post. Steve Edited April 3, 2011 by stevedm Quote Link to comment Share on other sites More sharing options...
stevedm Posted April 3, 2011 Author Report Share Posted April 3, 2011 New pics up Quote Link to comment Share on other sites More sharing options...
goldgus Posted April 4, 2011 Report Share Posted April 4, 2011 I'm all set to do the "self-port" on my S/C... (OK maybe not ALL set) What did you use to grind out the excess, a Dremel tool? And if so, which bit? And did you do it with the S/C on the car or did you pull it off first? I'm told its hard to keep shavings from flying around, and getting into the S/C inlet. Any tips would be greatly appreciated. Thanks, GUS Quote Link to comment Share on other sites More sharing options...
stevedm Posted April 4, 2011 Author Report Share Posted April 4, 2011 I'm all set to do the "self-port" on my S/C... (OK maybe not ALL set) What did you use to grind out the excess, a Dremel tool? And if so, which bit? And did you do it with the S/C on the car or did you pull it off first? I'm told its hard to keep shavings from flying around, and getting into the S/C inlet. Any tips would be greatly appreciated. Thanks, GUS I used a 25000 rpm die grinder hooked up to my air compressor. I used a rotary file bit....looked like a small vienna sausage with teeth but anyone would work. It takes a little effort so i chose one with fairly aggressive teeth then smoothed it off with a rotary stone and a hand file for the edges. I left the SC on the car and had no problem at all . I took three microfiber towels and washed them Then dried them in the dryer for 30 min to remove all fuzz. I stuffed two of them into the SC and had my shop vac running right close to the bit at all times. There was some metal thrown around but it was not bad at all. The SC was clean as a whistle after. I soaked a towel in alcohol after and cleaned the inside anyway but didn't get anything except some of the oily film that was on it. I would do it again anytime as i thought the process was very straight forward. I used the third towel to stuff into the air filter/MAF so no metal pieces would get in it from behind. Quote Link to comment Share on other sites More sharing options...
goldgus Posted April 5, 2011 Report Share Posted April 5, 2011 Sounds good man- Thx for the advice! GUS Quote Link to comment Share on other sites More sharing options...
69er-sagittarius Posted May 17, 2012 Report Share Posted May 17, 2012 (edited) Thx for the pictures now I can imagine how the EVAP Relocation kit should be connected. It is so easy and I have no idea why I did not figured it out ( http://www.teamshelby.com/forums/index.php/topic/74735-vmp-inlet-elbow-on-2011/page__pid__1300986?do=findComment&comment=1300986 ) Edited May 17, 2012 by 69er-sagittarius Quote Link to comment Share on other sites More sharing options...
