alaska Posted April 1, 2011 Report Share Posted April 1, 2011 Received my Fays2 Watts Link thanks to Randy Team Shelby Regional Director who had just purchased it and then they came out with the billet version so I scooped it up off here, now to start the install. Thanks again Randy, Brian Quote Link to comment Share on other sites More sharing options...
Cdvision Posted April 1, 2011 Report Share Posted April 1, 2011 Sweet!!!! Git 'er done!! Quote Link to comment Share on other sites More sharing options...
frydguy79 Posted April 1, 2011 Report Share Posted April 1, 2011 must be cold so cold up there that it froze it's nutz off, cause i shipped you a RED one your welcome Brian! Quote Link to comment Share on other sites More sharing options...
07SGT4578 Posted April 1, 2011 Report Share Posted April 1, 2011 That was going to be my question, how did you get a blue one. Randy just answered it. Thanx Randy. Quote Link to comment Share on other sites More sharing options...
alaska Posted April 1, 2011 Author Report Share Posted April 1, 2011 must be cold so cold up there that it froze it's nutz off, cause i shipped you a RED one your welcome Brian! Exactly Turned almost Ice Berg Blue Quote Link to comment Share on other sites More sharing options...
BigDan Posted April 1, 2011 Report Share Posted April 1, 2011 (edited) Nice, cant wait to hear your impressions. I want to go watts link in the future and show up all those vette guys at the track. Edited April 1, 2011 by BigDan Quote Link to comment Share on other sites More sharing options...
BLUE 2010 SHELBY GT 500 Posted April 2, 2011 Report Share Posted April 2, 2011 is the watts link only for drag racing application or is for road racng appl.also Quote Link to comment Share on other sites More sharing options...
alaska Posted April 2, 2011 Author Report Share Posted April 2, 2011 is the watts link only for drag racing application or is for road racng appl.also Both, especially road race for cornering Quote Link to comment Share on other sites More sharing options...
Shelby.GT500 Posted April 2, 2011 Report Share Posted April 2, 2011 Alaska can you tell us what year is your car. If it's 2011, do you have the svtpp? If not, is your suspension stock? Let us know how the installation went. Thanks. Oh and it looks awesome! Quote Link to comment Share on other sites More sharing options...
alaska Posted April 2, 2011 Author Report Share Posted April 2, 2011 Alaska can you tell us what year is your car. If it's 2011, do you have the svtpp? If not, is your suspension stock? Let us know how the installation went. Thanks. Oh and it looks awesome! 2010 The rest of the suspension is stock I will be upgrading next year as the wife has put a halt on any more mods this year, install was not bad at all did it on my ramps leveled the rear left to right, I did a couple of things different from the install guide to make things a little easier for make up. at the point were you measure passenger side watts bar and set the drivers side the same I removed the propeller and attached the propeller so I could torque them, then I remeasured the passenger side using the bottom edge of the propeller to the outside edge (I this was with it stretched straight on my bench) of the rod end and set the divers side exactly the same length, I also confirmed the length of threads on each rod end by measuring from bottom edge of the propeller to the edges of the jam nuts to get it spot on. Also on the 2010 the stock bolt on the passenger side for the pan hard support bar was installed from the axle side I had to pull the bolt back as far as I could, rotate the support bar at an angle then pull the bolt out at an angle past the spring in order to remove it, so I installed in the watts link on the opposite side. Quote Link to comment Share on other sites More sharing options...
Cobras55 Posted April 3, 2011 Report Share Posted April 3, 2011 Hey Alaska, what is the benefits of this watts link , I'm not to familiar with this part.....does it improve handling? I am lowered about an inch in the front and two in the back....with adj. panrod,cc plates,Lca's....and my car handles awesome...would this be an even bigger improvement? Quote Link to comment Share on other sites More sharing options...
alaska Posted April 3, 2011 Author Report Share Posted April 3, 2011 Hey Alaska, what is the benefits of this watts link , I'm not to familiar with this part.....does it improve handling? I am lowered about an inch in the front and two in the back....with adj. panrod,cc plates,Lca's....and my car handles awesome...would this be an even bigger improvement? I have not been able to take her out on the roads yet and I will be out of town for the next 3 weeks on business, when I return the snow should be gone and I will report, but from what I have read on the forums on here it should handle like a dream, and the cost is right. I will post when I return and am able to test. Brian Quote Link to comment Share on other sites More sharing options...
Shelbster Posted April 3, 2011 Report Share Posted April 3, 2011 I have not been able to take her out on the roads yet and I will be out of town for the next 3 weeks on business, when I return the snow should be gone and I will report, but from what I have read on the forums on here it should handle like a dream, and the cost is right. I will post when I return and am able to test. Brian Brian, So, did it come grabber blue or did you paint it? How much $$ Joe Quote Link to comment Share on other sites More sharing options...
alaska Posted April 4, 2011 Author Report Share Posted April 4, 2011 Brian, So, did it come grabber blue or did you paint it? How much $$ Joe Painted it myself, I picked up a 1/2 pint of grabber, reducer, 1 qt clear, reducer and hardener for $260.00 which gave me enough to paint my stock radiator cover, fuse box and the fays 2 and I still have enough to do some more projects, I posted the Radiator cover and fuse box on here to should be a few threads down. Thanks Brian and no I am not a painter I picked up the gun last year off craigslist cheap its a Sata I planed on shooting my 66 lemans when I get it finished. Quote Link to comment Share on other sites More sharing options...
Shelbster Posted April 4, 2011 Report Share Posted April 4, 2011 Painted it myself, I picked up a 1/2 pint of grabber, reducer, 1 qt clear, reducer and hardener for $260.00 which gave me enough to paint my stock radiator cover, fuse box and the fays 2 and I still have enough to do some more projects, I posted the Radiator cover and fuse box on here to should be a few threads down. Thanks Brian and no I am not a painter I picked up the gun last year off craigslist cheap its a Sata I planed on shooting my 66 lemans when I get it finished. Thanks, Looks great! Gives me some ideas. Where are you in Alaska? I use to live in Anchorage years ago. Joe Quote Link to comment Share on other sites More sharing options...
alaska Posted April 4, 2011 Author Report Share Posted April 4, 2011 Thanks, Looks great! Gives me some ideas. Where are you in Alaska? I use to live in Anchorage years ago. Joe Eagle River all the way up the end of the valley by the visitor center. Florida sounds nice, the wife and I are looking for a second house in warmer climate thinking of Phoenix, Quote Link to comment Share on other sites More sharing options...
