zombeast Posted March 30, 2011 Report Share Posted March 30, 2011 Do you have to leave the rear O2 sensors in with an O/R pipe since they are turned off in the tune? Quote Link to comment Share on other sites More sharing options...
0201212 Posted March 30, 2011 Report Share Posted March 30, 2011 No they are not required. You can just plug the holes or put a wide band in one of them to keep am eye on your A/F ratio. Quote Link to comment Share on other sites More sharing options...
zombeast Posted March 30, 2011 Author Report Share Posted March 30, 2011 No they are not required. You can just plug the holes or put a wide band in one of them to keep am eye on your A/F ratio. That's what I was hoping for. Thanks! Quote Link to comment Share on other sites More sharing options...
2010KonaBlueGT Posted March 30, 2011 Report Share Posted March 30, 2011 Do you have to leave the rear O2 sensors in with an O/R pipe since they are turned off in the tune? The rear sensors are to test the Catalytic Converter function. If the front and rear sensor both measure the same amount of Oxygen in the exhaust stream, it means the Cat is not working. It is looking for a DIFFERENCE between the two. So if you put a Off-road pipe on your car (which I ASSUME means there are no Cats in it) the sensor will see the same O2 content pre and post Cat and set a code (bad Cat). As someone else already said, you would need a aftermarket tune that turns the rear sensors off. And that does leave you with a good place for a UEGO sensor to momitor AFR. And for what it's worth, it's against Federal Law to disable or remove any emission control device or system from a vehicle that is driven on a public road/street (which is what you'd be doing). Phill Quote Link to comment Share on other sites More sharing options...
zombeast Posted April 1, 2011 Author Report Share Posted April 1, 2011 The rear sensors are to test the Catalytic Converter function. If the front and rear sensor both measure the same amount of Oxygen in the exhaust stream, it means the Cat is not working. It is looking for a DIFFERENCE between the two. So if you put a Off-road pipe on your car (which I ASSUME means there are no Cats in it) the sensor will see the same O2 content pre and post Cat and set a code (bad Cat). As someone else already said, you would need a aftermarket tune that turns the rear sensors off. And that does leave you with a good place for a UEGO sensor to momitor AFR. And for what it's worth, it's against Federal Law to disable or remove any emission control device or system from a vehicle that is driven on a public road/street (which is what you'd be doing). Phill Thanks for the detailed response. Quote Link to comment Share on other sites More sharing options...
