justindewoody Posted March 15, 2011 Report Share Posted March 15, 2011 I got the front and rear Shelby/Baer Extreme Plus Brakes coming, and I've heard that the rear install is pretty in-depth. If any of you have done it, please tell me what's involved. I hear that you have to pull the axles. And I hear that in order to pull the axles, you gotta remove the pumpkin. After I remove the pumpkin, do I need new gaskets? I need to know all the details BEFORE I begin the installation. Please help me out here. Thanks. Link to comment Share on other sites More sharing options...
Slabo Posted March 15, 2011 Report Share Posted March 15, 2011 Its a bit involved but very doable. Here is a thread I did when I installed my rear Baer's. It's a great opportunity to put on a different diff cover which is what I did. The new cover installs with RTV gasket maker. Just be careful removing and re-installing the pinion lock bolt as you don't want to strip it. Re-install it with lock tite. Also be careful removing the axles not to damage the bearing seals. Shelby Extreme (Baer) rear brake install w/ pics Link to comment Share on other sites More sharing options...
1badshelby Posted March 15, 2011 Report Share Posted March 15, 2011 I got the front and rear Shelby/Baer Extreme Plus Brakes coming, and I've heard that the rear install is pretty in-depth. If any of you have done it, please tell me what's involved. I hear that you have to pull the axles. And I hear that in order to pull the axles, you gotta remove the pumpkin. After I remove the pumpkin, do I need new gaskets? I need to know all the details BEFORE I begin the installation. Please help me out here. Thanks. You only have to remove the cross shaft and c clips to pull the axles. It's not that bad. Don't forget to refill with a good synthetic gear lube and bottle of friction modifier. Mike Link to comment Share on other sites More sharing options...
justindewoody Posted March 16, 2011 Author Report Share Posted March 16, 2011 You only have to remove the cross shaft and c clips to pull the axles. It's not that bad. Don't forget to refill with a good synthetic gear lube and bottle of friction modifier. Mike I would appreciate it if everyone would weigh in on synthetic gear lube. What do you recommend? Link to comment Share on other sites More sharing options...
vapor08GT500 Posted March 16, 2011 Report Share Posted March 16, 2011 I would appreciate it if everyone would weigh in on synthetic gear lube. What do you recommend? Royal Purple 75-140 Link to comment Share on other sites More sharing options...
jcthorne Posted March 16, 2011 Report Share Posted March 16, 2011 Redline 75-140. And it does not need the friction modifier additive. Link to comment Share on other sites More sharing options...
