michschi Posted March 15, 2011 Report Share Posted March 15, 2011 How can I tell if I have it for sure? Quote Link to comment Share on other sites More sharing options...
shelbyguy470 Posted March 15, 2011 Report Share Posted March 15, 2011 When you turn on the key you should see a warning light. I believe all 2007 on had it. Quote Link to comment Share on other sites More sharing options...
twitch43 Posted March 15, 2011 Report Share Posted March 15, 2011 In 2007 Ford introduced the banded TPMS on the Mustang. They changed over to a valve mounted sensor for the 2010 model year which by the way are not compatible with the '07-'09 model years. Quote Link to comment Share on other sites More sharing options...
07SGT4578 Posted March 15, 2011 Report Share Posted March 15, 2011 All 2007 SGT's have TPMS Quote Link to comment Share on other sites More sharing options...
Blown Away Posted March 15, 2011 Report Share Posted March 15, 2011 In 2007 Ford introduced the banded TPMS on the Mustang. They changed over to a valve mounted sensor for the 2010 model year which by the way are not compatible with the '07-'09 model years. I have the valve stem mounted TPMS in my 20" wheels and have not had any problems. Dan Quote Link to comment Share on other sites More sharing options...
07SGT4578 Posted March 15, 2011 Report Share Posted March 15, 2011 I have the valve stem mounted TPMS in my 20" wheels and have not had any problems. Dan That is nice to know, thanx Now I really need another set of wheels Quote Link to comment Share on other sites More sharing options...
andrewnagle1964 Posted March 15, 2011 Report Share Posted March 15, 2011 I have the valve stem mounted TPMS in my 20" wheels and have not had any problems. Dan Did you have to do anything special or different, to make this work ? Thanks Andrew Quote Link to comment Share on other sites More sharing options...
Blown Away Posted March 15, 2011 Report Share Posted March 15, 2011 Did you have to do anything special or different, to make this work ? Thanks Andrew Nope, just installed them and then used the programming tool. Which you have to do any ways. Dan Quote Link to comment Share on other sites More sharing options...
07SGT5687 Posted March 22, 2011 Report Share Posted March 22, 2011 BTW, don't let a dealer gouge on reprogramming... AM has the handheld tool for like $45. I've heard it works perfectly. Quote Link to comment Share on other sites More sharing options...
AstroDan Posted March 22, 2011 Report Share Posted March 22, 2011 I may be strange, but when I changed out my tires/wheels, I didn't re-install TPMS. I live with the idiot light after hitting reset button every start-up. It bothers me not at all. Part of Betsy's charm. Quote Link to comment Share on other sites More sharing options...
07SGT5687 Posted March 22, 2011 Report Share Posted March 22, 2011 I may be strange, but when I changed out my tires/wheels, I didn't re-install TPMS. I live with the idiot light after hitting reset button every start-up. It bothers me not at all. Part of Betsy's charm. LOL.. . to each his own... right now I feel like a pilot when I get in. Tire Sensor Malfunction - RESET... Traction Control System - OFF. Ignition... Stella is GO, Stella is GO. Quote Link to comment Share on other sites More sharing options...
03 DSG Snake Posted April 1, 2011 Report Share Posted April 1, 2011 I have the valve stem mounted TPMS in my 20" wheels and have not had any problems. Dan Everything I've read states that the 2007-2009 sensors only work for those cars, and the 07-09 TPMS system is not compatible with the 10-11. Are you using the OEM Ford sensors? Quote Link to comment Share on other sites More sharing options...
