GT500KR_DE Posted February 3, 2011 Report Share Posted February 3, 2011 I tried to remove the orignal KR rear spoiler and change it into the SuperSnake spoiler. My problem is that the KR spoiler won't get off the lid. I tried anything like heat it up, using a plastic wedge... The tape is so hard to get off that I have to damage lid to get off the spoiler. Is there another way?! A special liquid or something else to solve the adhesive? Thanks a lot for your answers. Link to comment Share on other sites More sharing options...
WH RIECKE Posted February 3, 2011 Report Share Posted February 3, 2011 Well it can be done, i took mine off and sent it in for carol to sign. First lots of time. I removed the lid liner and used a heat gun on the under side of the trunk lid, be very careful, not to much heat or you could lift the stripes also.I used some door shim stock (wood) i had and a lot of effort. There is two rows of very good 3m tape under your spoiler. They run the lenght of it.Aprox 4 inches apart. I started heating it and shoving the shim stock under it from the leading edge and used an old t-shirt between the shim and the paint to protect it. It will come off, you will just have to work the shims along the edge.You will be cutting the tape in half by doing this and when you do get it off be prepared to spend almost as much time cleaning the old tape off the trunk lid, i used lighter fluid to do that, like i said that is some really good tape, Hope that helps,Bill Link to comment Share on other sites More sharing options...
GT500KR_DE Posted February 4, 2011 Author Report Share Posted February 4, 2011 Oh yeah! Worked great :-) I heated it up and took a nylon thread to cut the 3M tape. It takes only 15 Minutes until the spoiler "droped" off :-) Thanks for your help! Link to comment Share on other sites More sharing options...
WH RIECKE Posted February 4, 2011 Report Share Posted February 4, 2011 Oh yeah! Worked great :-) I heated it up and took a nylon thread to cut the 3M tape. It takes only 15 Minutes until the spoiler "droped" off :-) Thanks for your help! Link to comment Share on other sites More sharing options...
txcobra Posted February 5, 2011 Report Share Posted February 5, 2011 So how about posting up some pics when you put the new one on? Link to comment Share on other sites More sharing options...
shel-b001 Posted February 5, 2011 Report Share Posted February 5, 2011 Before & after pictures would be nice. Link to comment Share on other sites More sharing options...
