PARTS DUDE Posted February 3, 2011 Report Share Posted February 3, 2011 I have read about reusing the factory gaskets. Good with that. I was suggested to use a bead of silicone on both sides of the gasket. Has anybody used High temp silicone or should I use them without the silicone. The header bolts. Should I use locktite on the threads? I am about to install the passenger side tomorrow night Thank you guys for the help Link to comment Share on other sites More sharing options...
LSXKILLER Posted February 24, 2011 Report Share Posted February 24, 2011 I have read about reusing the factory gaskets. Good with that. I was suggested to use a bead of silicone on both sides of the gasket. Has anybody used High temp silicone or should I use them without the silicone. The header bolts. Should I use locktite on the threads? I am about to install the passenger side tomorrow night Thank you guys for the help I'm sure you already have these on by now but yes yous can use hi temp rtv on both sides of the factory gaskets. I've used it and i know of a hop tht does it on all header installs. Its definately not going ot hurt anything. Link to comment Share on other sites More sharing options...
kahmann Posted February 24, 2011 Report Share Posted February 24, 2011 I've used high temp silicone and it works great. As for bolts, go with Stage 8 locking header bolts and you won't have any worries. Good luck Link to comment Share on other sites More sharing options...
SGT/SC#0471 Posted February 24, 2011 Report Share Posted February 24, 2011 I've used high temp silicone and it works great. As for bolts, go with Stage 8 locking header bolts and you won't have any worries. Good luck What Ken said...I do not reuse gaskets however. False economy IMO. Link to comment Share on other sites More sharing options...
