Nate8509 Posted February 2, 2011 Report Share Posted February 2, 2011 hi guys i was trying to understand this suspension stuff and was wondering what the need for Adjustable lower control arms is? i going Adjustable upper control arm do i need the lowers that way to Link to comment Share on other sites More sharing options...
2010KonaBlueGT Posted February 10, 2011 Report Share Posted February 10, 2011 hi guys i was trying to understand this suspension stuff and was wondering what the need for Adjustable lower control arms is? i going Adjustable upper control arm do i need the lowers that way to If you run the LCA relocation brackets you will need adjustable lowers. The relocation brackets lower the axle end of the LCA so you need a slightly longer arm to compensate for the angle creating the need for one. And if you lower your car, there's a real good chance you'll need the relocation brackets to adjust your IC so you don't lose traction from moving the IC forward in the car. When you lanuch the car, you want the tires to push DOWN into the track, not suck up into the body (i.e. squat the car). Phill Link to comment Share on other sites More sharing options...
Nate8509 Posted February 14, 2011 Author Report Share Posted February 14, 2011 thanks phill i will need adj lowers then glad i asked i'm still learning about all this suspension stuff Link to comment Share on other sites More sharing options...
