FordFan1 Posted November 2, 2011 Report Share Posted November 2, 2011 Kerry, Your 01 Bullitt came with underdrive pulleys from Ford. Did you feel Steeda pulleys were better? I'm just curious because I used to own 01 Bullitt #2371. IF I remember correctly, Ford only reduced the alt and oversized the water pump and used the standard 2v OEM balancer pulley. I only used the Steeda balancer and water pump and left the Bullitt alt pulley alone. Mine was Black Bullitt #2343 Link to comment Share on other sites More sharing options...
SoFL05GT Posted November 2, 2011 Report Share Posted November 2, 2011 IF I remember correctly, Ford only reduced the alt and oversized the water pump and used the standard 2v OEM balancer pulley. I only used the Steeda balancer and water pump and left the Bullitt alt pulley alone. Mine was Black Bullitt #2343 Thanks..I never checked them out closely, so I can't confirm. I did install Steeda underdrive pulleys on my 05 GT, and for sure noticed an improvement with no negative issues. My #2371 was True Blue. Link to comment Share on other sites More sharing options...
07SGTC Posted November 12, 2011 Report Share Posted November 12, 2011 Steeda UnderDrive Pulleys arrived yesterday. Now just need to find the time to install them. Any words of wisdom for the install? Link to comment Share on other sites More sharing options...
Larry T Posted November 12, 2011 Report Share Posted November 12, 2011 Steeda UnderDrive Pulleys arrived yesterday. Now just need to find the time to install them. Any words of wisdom for the install? Saleen instructions http://www.saleeninstructions.com/docs/Install%20Manual/Data/Powertrain/10-8002-C15768A.pdf Link to comment Share on other sites More sharing options...
Jer Posted November 12, 2011 Report Share Posted November 12, 2011 Any words of wisdom for the install? Rent, borrow, or buy a GOOD pulley puller. No Harbor Freight tools! While I'm perfectly willing to get certain things there, a good puller is worth spending a few bucks on. Also, I think NAPA/Advance/AutoZone have good ones they loan out. Jer Link to comment Share on other sites More sharing options...
07SGTC Posted November 12, 2011 Report Share Posted November 12, 2011 Thanks for the tips!!!!!!!!!!! Link to comment Share on other sites More sharing options...
FordFan1 Posted November 13, 2011 Report Share Posted November 13, 2011 Steeda UnderDrive Pulleys arrived yesterday. Now just need to find the time to install them. Any words of wisdom for the install? The right tools makes the job pretty easy- Here is the Puller and Installer #'s I borrowed from Autozone on two occasions- (the tools will be listed in their information to be used for Chrysler applications, don't let that stop you) 27139 - 3 Jaw Style puller 27144 - Installer tool Here is another set of directions for your review, it also confirms the puller/installer numbers I provided http://www.stangnet.com/2007/02/12/s197-ford-mustang-underdrive-pulley-install/ Also if at all possible pick up a new FORD pulley bolt and follow the torque streach torque procedure carefully- GL Link to comment Share on other sites More sharing options...
07SGTC Posted November 13, 2011 Report Share Posted November 13, 2011 The right tools makes the job pretty easy- Here is the Puller and Installer #'s I borrowed from Autozone on two occasions- (the tools will be listed in their information to be used for Chrysler applications, don't let that stop you) 27139 - 3 Jaw Style puller 27144 - Installer tool Here is another set of directions for your review, it also confirms the puller/installer numbers I provided http://www.stangnet....pulley-install/ Also if at all possible pick up a new FORD pulley bolt and follow the torque streach torque procedure carefully- GL Great info! Thanks!!!!!!!!!!! Link to comment Share on other sites More sharing options...
