wannab Posted January 20, 2011 Report Share Posted January 20, 2011 I OWN AN 07 GT-H CONV. JUST WONDERING HOW MANY WIRE "SEALS" THERE ARE IN THE ENGINE COMPARTMENT AND THERE (OR ITS) LOCATIONS? MANY THANKS FOR ANY INFORMATION. ALSO DID THE CONV. BOOT COME WITH ANYONES GT-H? MINE DID NOT HAVE ONE AND IS IT JUST THE FORD FACTORY BOOT.? THANKS AGAIN Link to comment Share on other sites More sharing options...
Larry T Posted January 20, 2011 Report Share Posted January 20, 2011 I OWN AN 07 GT-H CONV. JUST WONDERING HOW MANY WIRE "SEALS" THERE ARE IN THE ENGINE COMPARTMENT AND THERE (OR ITS) LOCATIONS? MANY THANKS FOR ANY INFORMATION. ALSO DID THE CONV. BOOT COME WITH ANYONES GT-H? MINE DID NOT HAVE ONE AND IS IT JUST THE FORD FACTORY BOOT.? THANKS AGAIN Here is a picture of the seal The boot is the factory one but Hertz locations removed them before rental and once the cycle was complete it should have been put in the truck but if it isn't there it is probably gone. Link to comment Share on other sites More sharing options...
wannab Posted January 20, 2011 Author Report Share Posted January 20, 2011 Here is a picture of the seal The boot is the factory one but Hertz locations removed them before rental and once the cycle was complete it should have been put in the truck but if it isn't there it is probably gone. THANK YOU FOR YOUR ANSWER SO THERE IS ONLY ONE SEAL...SO MUCH FOR THE BOOT AND BY THE WAY NICE PAIR OF 44'S Link to comment Share on other sites More sharing options...
Larry T Posted January 20, 2011 Report Share Posted January 20, 2011 THANK YOU FOR YOUR ANSWER SO THERE IS ONLY ONE SEAL...SO MUCH FOR THE BOOT AND BY THE WAY NICE PAIR OF 44'S Which pair ?????? HEHEHHEHEH Yes only one engine seal, if you need to get any work done and there is a chance it will get broken you can unbolt the valve cover and move it out of the way as these seals are no longer a stock item anywhere Also since its a stock part you can get the boot from a dealer, bone yard, craigslist, or swap meet Link to comment Share on other sites More sharing options...
