Raytags Posted January 11, 2011 Report Share Posted January 11, 2011 Hi! If anyone have a problem with a rattle with the passenger side seat, let me know, and if you have a solution a this problem Thanks! Ray Link to comment Share on other sites More sharing options...
03 DSG Snake Posted January 11, 2011 Report Share Posted January 11, 2011 What does it sound like? Link to comment Share on other sites More sharing options...
old man Posted January 12, 2011 Report Share Posted January 12, 2011 Many of us have the same problem. Also pass side door rattle. Don't know how to fix it. Harley Link to comment Share on other sites More sharing options...
gth0007 Posted January 13, 2011 Report Share Posted January 13, 2011 Hi! If anyone have a problem with a rattle with the passenger side seat, let me know, and if you have a solution a this problem Thanks! Ray GT-Hs use totally stock Mustang interiors so if there is a recurring problem of seat rattle then the same should be happening on regular production Mustangs. You may want to ask your Ford dealer if they have heard of this problem and if there is a fix. About the only thing that can rattle on a seat is if the four seat to floor retaining bolts are loose or the seat back adjustment is not quite right. Also on the passenger seat, it is common for the shoulder harness, when not in use, to bump against the plastic interior trim creating a noise. The door rattle mentioned on another post has to do with the window adjustment and is common on many Mustangs. Hope this helps. Larry Link to comment Share on other sites More sharing options...
MustangTom Posted January 14, 2011 Report Share Posted January 14, 2011 I've definately got the seat rattle. When I bought the car I had a shop change all the fluids and asked them to take a look at the seat while they were at it. They said they tightened up the slider bar, but it didn't fix it. If I apply pressure to the seat back towards the passenger door it will stop. I don't know if that indicates a problem with the seat back, or if the pressure is tightening up something else. I'd love to find a fix! Link to comment Share on other sites More sharing options...
Shelby-GT-H Posted January 14, 2011 Report Share Posted January 14, 2011 I've definately got the seat rattle. When I bought the car I had a shop change all the fluids and asked them to take a look at the seat while they were at it. They said they tightened up the slider bar, but it didn't fix it. If I apply pressure to the seat back towards the passenger door it will stop. I don't know if that indicates a problem with the seat back, or if the pressure is tightening up something else. I'd love to find a fix! I have the seat rattle also. Attempted to repair, but seems seat back is causing the rattle on mine.... Link to comment Share on other sites More sharing options...
stpracer43 Posted January 14, 2011 Report Share Posted January 14, 2011 I noticed this same issue when I rented a GT-H vert back in 2008. Thought maybe there was a wheel out of balance. Might try reclining the seat back further to put a bit more leverage on the hinges to seat base. I did find when I place my backpack in the seat against the seat back it tended to vibrate much less. Keith Link to comment Share on other sites More sharing options...
dexterm1215 Posted January 17, 2011 Report Share Posted January 17, 2011 I've definately got the seat rattle. When I bought the car I had a shop change all the fluids and asked them to take a look at the seat while they were at it. They said they tightened up the slider bar, but it didn't fix it. If I apply pressure to the seat back towards the passenger door it will stop. I don't know if that indicates a problem with the seat back, or if the pressure is tightening up something else. I'd love to find a fix! Link to comment Share on other sites More sharing options...
dexterm1215 Posted January 17, 2011 Report Share Posted January 17, 2011 I had that same problem a little over a year ago. The first Ford dealership I took it to told me it couldn't be fixed. I then took it to another dealership, and they had it fixed in 3 days. I believe they had to replace the seat back. Some part inside of the seat back had broken. Link to comment Share on other sites More sharing options...
