2010KonaBlueGT Posted December 28, 2010 Report Share Posted December 28, 2010 As the title says, can you put the Shelby/Baer 6S brake calipers & rotors on the front of a KR with the stock/OE 18" Alcoa Dura-Bright wheels or is there a clearence problem? What about the rear wheels and the Shelby/Baer Eradispeed rear brake rotors (14"?)? For those that have added the Baer 6S brakes on ANY GT500, will the FRPP/KR front brake cooling duct kit work with them? I see that you are supposed to eliminate the dust OEM shields when you add the 6S brakes but the instructions don't say anything about the FRPP/KR vented shields. From the looks of them, they are the same item just with a tube welded on them. Or does the KR use the JLT/Shelby style of duct that is just the tube with two mounting ears on it? If I can't use the FRPP cooling ducts with the Baer brakes, I may have a set for sale, new in box-never been opened! Thanks in advance, Phill Pollard Link to comment Share on other sites More sharing options...
Cali_KR Posted December 28, 2010 Report Share Posted December 28, 2010 Hi Phill, I added the rears to my 08 convertible and had the stock 18" SVT wheels and there were no clearance issues. I have no input on the fronts or the ducting clearances. Tom Link to comment Share on other sites More sharing options...
Rag Top Day Posted December 28, 2010 Report Share Posted December 28, 2010 I have installed the Shelby Extreme's 6S's with no problem on the front of the KR, you do need to trim the shields and masage a bit to make them to clear thought. No issues with the wheels. Be sure to check weight placement as it is close. Link to comment Share on other sites More sharing options...
Jody Posted January 1, 2011 Report Share Posted January 1, 2011 I put the front and rear Baer 6 piston brakes on my KR and I DID have clearance issues. The wheels fit on, but there was about the thickness of a piece of paper gap clearance. I was not going to risk damage to my calipers and wheels so I put on the 20' Alcoas. Shelby Autos claims they have no issues with this set up, but I sure did. Link to comment Share on other sites More sharing options...
