davegt500 Posted December 13, 2010 Report Share Posted December 13, 2010 Before I animalize my new ride...In the trunk the side carpeting is held in place by smooth headed plastic fasteners in a few places. How are those removed or released? Pull on the carpeting around them? Thanks Quote Link to comment Share on other sites More sharing options...
Colleton Posted December 13, 2010 Report Share Posted December 13, 2010 You need a trim removal took. It's kind of like a little spade fork that slides under the head and levers it up. Quote Link to comment Share on other sites More sharing options...
Torched10 Posted December 13, 2010 Report Share Posted December 13, 2010 You need a trim removal took. It's kind of like a little spade fork that slides under the head and levers it up. sounds like the same tool i use for removing carpet staples.Its about 4in long and has a kind of "nail remover" fork o the end--got mine at Ace Hardware Quote Link to comment Share on other sites More sharing options...
BDrool Posted December 13, 2010 Report Share Posted December 13, 2010 You need a trim removal took. It's kind of like a little spade fork that slides under the head and levers it up. You will probably need extra fasteners if you plan to put the carpet/body parts back. They are one time use but sometimes you can reinstall them. Quote Link to comment Share on other sites More sharing options...
davegt500 Posted December 13, 2010 Author Report Share Posted December 13, 2010 Thanks for the helpful info. Quote Link to comment Share on other sites More sharing options...
cobra2564 Posted December 13, 2010 Report Share Posted December 13, 2010 You will probably need extra fasteners if you plan to put the carpet/body parts back. They are one time use but sometimes you can reinstall them. Quote Link to comment Share on other sites More sharing options...
cobra2564 Posted December 13, 2010 Report Share Posted December 13, 2010 When I got my 2010 500 I took off the plastic radiator cover to clean bugs off of rad. I saw that the car is held together in many places by the same type of fastener. They looked like something I should have around in bulk just in case. I had Ford dealer parts guy look up and they didnt stock. I wanted to order a dozen or so spares. I forget the price but it was something outrageous like $4.00 a piece. Im kind of a spend thrift cause I believe in OEM stuff but that was stupid high! O'Reillys has some pretty close looking on a generic rack for really cheap so I loaded up. Just an FYI. Quote Link to comment Share on other sites More sharing options...
davegt500 Posted December 13, 2010 Author Report Share Posted December 13, 2010 When I got my 2010 500 I took off the plastic radiator cover to clean bugs off of rad. I saw that the car is held together in many places by the same type of fastener. They looked like something I should have around in bulk just in case. I had Ford dealer parts guy look up and they didnt stock. I wanted to order a dozen or so spares. I forget the price but it was something outrageous like $4.00 a piece. Im kind of a spend thrift cause I believe in OEM stuff but that was stupid high! O'Reillys has some pretty close looking on a generic rack for really cheap so I loaded up. Just an FYI. Thanks for info. Guess I better get some of those. Quote Link to comment Share on other sites More sharing options...
BDrool Posted December 13, 2010 Report Share Posted December 13, 2010 (edited) When I got my 2010 500 I took off the plastic radiator cover to clean bugs off of rad. I saw that the car is held together in many places by the same type of fastener. They looked like something I should have around in bulk just in case. I had Ford dealer parts guy look up and they didnt stock. I wanted to order a dozen or so spares. I forget the price but it was something outrageous like $4.00 a piece. Im kind of a spend thrift cause I believe in OEM stuff but that was stupid high! O'Reillys has some pretty close looking on a generic rack for really cheap so I loaded up. Just an FYI. Doesn't the radiator cover use the reusable pins? On mine, 2010, I pull the center out until stop, carefull not to go to far, and then the pin comes right out. To put it back, push the pin in the hole then push the center pin in to lock. Edited December 14, 2010 by BDrool Quote Link to comment Share on other sites More sharing options...
cobra2564 Posted December 16, 2010 Report Share Posted December 16, 2010 Doesn't the radiator cover use the reusable pins? On mine, 2010, I pull the center out until stop, carefull not to go to far, and then the pin comes right out. To put it back, push the pin in the hole then push the center pin in to lock. Yes, they are. I assumed we they were the same. You know what you get when you assume! That particular one is used in several places, though and they can get lost or goofed up when taking on and off. Just me, I suppose........... Quote Link to comment Share on other sites More sharing options...
