Replacing PAI light bulb
If your talking about the PIAA lights down low, next to the brake duct, it's a simple job. (I replaced one of the lenses that was cracked by a low-flying rock!) There are two screws on the housing that hold the front lens on, one on each side. LOOSEN, but DO NOT REMOVE the screws, then gently pull the lens away from the body of the light. Careful with the O-ring! You then have easy access to the bulb. Switch bulbs, (wear gloves as finger oil/moisture can cause the bulb to break/burn out), then reinstall the lens in the reverse order.
Sam
