COBRA SCOTTY Posted December 6, 2010 Report Share Posted December 6, 2010 HI GUYS , I HAVE FOR SALE A SET OF 4 DRAG WHEELS AND TIRES WITH (TMPS) ; THE FRONTS ARE CUSTOM NARROWED 2008 SVT WHEELS BY WELDCRAFT ; AND ARE (18 X 5) WITH MICKEY THOMPSON SPORTSMAN S/R IN A 26 X 6.0 X 18LT. BOTH THE WHEELS AND TIRES ARE BRAND NEW , NEVER HAVE BEEN ON MY CAR. THESE WILL ALSO WORK WITH BREMBO AND SHELBY BAER BIG BRAKES. THE REARS ARE WIDEN BY WELDCRAFT ; AND ARE (18 X 11.75) WITH NITTO EXTREMES IN A 305 X 35 X 18 THAT HAVE BEEN HEAT CYCLED BY THE NITTO FACTOR TO INCREASE LONGEVITY AND EVEN OUT TIRE WEAR. THEY ONLY HAVE 8 QUARTER MILE RUNS ON THEM AND A ADDITIONAL 196 MILES ; GOING TO AND FROM MILAN DRAGWAY TWICE IN MICHIGAN. NEEDLESS TO SAY THESE WHEELS AND TIRE ARE NEW , IN EXCELLENT CONDITION. I SPENT A LITTLE OVER $ 3,238 TO DESIGN THIS COMBINATION INCLUDING ALL OF THE ABOVE WORK DONE BY WELDCRAFT , THE TPMS FOR ALL FOUR OEM SVT WHEELS , TIRES, HEAT CYCLING , WHEELS AND MOUNTING, HIGH SPEED BALANCING. I AM ASKING $ 2,250 FOR THE PACKAGE PLUS SHIPPING TO YOU THE WHEELS AND TIRES ARE LOCATED WITH ME IN ARKANSAS ABOUT AN HOUR FROM MEMPHIS TN. TRY TO BUILD THIS COMBINATION FOR LESS ; YOU JUST CAN NOT DO IT. SO DO YOURSELF A FAVOR AND SAVE A $1,000 + Dollars and buy them from me. If you you are in the 12's you can be in the 11's and if your in the 11's this is the set-up that can put you into the 10's. There is not a better tire and wheel combination around for this price. MATTER OF FACT THERE ARE NMRA RACERS RUNNING IN THE HIGH 9's WITH THIS COMBINATION AND THAT'S A FACT. THIS COMBINATION PROVIDES SIGNIFICANTLY MORE TRACTION THAN ANY 20 INCH TIRE AND WHEEL COMBINATION. THAT BEING SAID, THIS IS THE COMBINATION USED BY MANY OF THE NMRA RACERS RUNNING MUSTANGS WITH 600-800 RWHP. HOWEVER, I WOULD RECOMMEND THE REARS TIRES BE CHANGED OUT WHEN THEY ARE DONE EVEN THOUGH I WAS ABLE TO OBTAIN 60FT TIMES IN 1.72 SECONDS WITH THEM. THE NITTOS IN A 305/40/18 WILL ALLOW YOU TO OBTAIN 1.60 60FT TIMES. THE REASON I KNOW AND SAY THIS IS WHEN I WAS WORKING FOR FORD RACING THIS PARTICULAR TIRE WITH THE AIR PRESSURE SET FOR STREET OR STRIP PROVIDED THE EXACT SAME TYPE OF RESULTS AS A RACING SLICK ALLOWING THE TIRE TO SQUAT, FLEX AND GET SIGNIFICANTLY MORE TRACTION THAN A 20 INCH WHEEL N TIRE COMBINATION, BUT STILL PROVIDED EXCELLENT STREETIBILTY. PLEASE PM ME IF YOU ARE INTERESTED IN THIS PACKAGE AND INCLUDE YOUR ZIP CODE SO I CAN GIVE YOU A SHIPPING QUOTE. I HAVE RECIEVED SEVERAL REQUEST TO SPLIT THE SET SO I WILL CONSIDER THAT AS AN OPTIONS. THANKS FOR YOUR RESPONSES IN ADVANCE. SCOTTY Rear pics ; Front side / Back side Link to comment Share on other sites More sharing options...
COBRA SCOTTY Posted December 6, 2010 Author Report Share Posted December 6, 2010 more pics Rear pics Link to comment Share on other sites More sharing options...
COBRA SCOTTY Posted December 6, 2010 Author Report Share Posted December 6, 2010 more pics Rear pic Link to comment Share on other sites More sharing options...
COBRA SCOTTY Posted December 6, 2010 Author Report Share Posted December 6, 2010 more pics PIC OF FRONT SKINNY'S ALLOWING FOR GREAT WEIGHT TRANSFER AND SQUATING OF THE REAR TIRES AS THE FRONTS TIRES COME OFF THE GROUND. Link to comment Share on other sites More sharing options...
COBRA SCOTTY Posted December 6, 2010 Author Report Share Posted December 6, 2010 more pics New Front tires sticker Link to comment Share on other sites More sharing options...
COBRA SCOTTY Posted December 6, 2010 Author Report Share Posted December 6, 2010 more pics Front wheels pic ; front side / back side Link to comment Share on other sites More sharing options...
COBRA SCOTTY Posted December 6, 2010 Author Report Share Posted December 6, 2010 HERE IS A PIC OF MY GT500 WHEN IT ONLY HAD 563 RWHP AND STOCK TIRES ON THE FRONT ; IF YOU LOOK CLOSE AND ENLARGE THE PICTURE MY TIRES ARE JUST ABOUT 1-2 INCH OFF THE GROUND USING THE VERY SAME REAR TIRES AND RIMS THAT I HAVE FOR SALE. ALSO LOOK AT THE BACK OF THE CAR SQUATING DOWN AS THE FRONT END LIFTS UP AND BECOMES FULLY EXTENDED TO THE LIMIT OF THE FRONT STRUTS. NOW IMAGINE SAVING 40 LBS OF WEIGHT BY HAVING THE SKINNY'S UP FRONT ; YOU WILL NOW BE 4-8 INCH OFF THE GROUND ALLOWING FOR EVEN MORE WEIGHT TRANSFER AND LOWER 60FT TIMES AND 1/4 MILE TIMES. Link to comment Share on other sites More sharing options...
COBRA SCOTTY Posted December 14, 2010 Author Report Share Posted December 14, 2010 I HAVE RECIEVED SEVERAL REQUESTS TO SPLIT THE SET SO I WILL CONSIDER THAT OPTIONS. THANKS, RESPECTFULLY, SCOTTY G. Link to comment Share on other sites More sharing options...
