dffej51 Posted December 5, 2010 Report Share Posted December 5, 2010 This will be my first winter with my Shelby and here in Pennsylvania there are not many days the car will see the light of day. I have the battery tender that I used on my Roush last winter and plan to use it on the Shelby. I have one simple question, do those of you who use battery tenders on your Shelbys place the cable clips on both battery terminals or do you ground one somewhere under the hood. If you ground one, where is the rcommeneded or best place to connect the clip? Thanks. Link to comment Share on other sites More sharing options...
MTB65 Posted December 5, 2010 Report Share Posted December 5, 2010 This will be my first winter with my Shelby and here in Pennsylvania there are not many days the car will see the light of day. I have the battery tender that I used on my Roush last winter and plan to use it on the Shelby. I have one simple question, do those of you who use battery tenders on your Shelbys place the cable clips on both battery terminals or do you ground one somewhere under the hood. If you ground one, where is the rcommeneded or best place to connect the clip? Thanks. Putting it on the ground of the battery or a ground in the engine compartment makes no difference...It's all the same ground plane. Link to comment Share on other sites More sharing options...
ilmor Posted December 6, 2010 Report Share Posted December 6, 2010 I just clip mine to the battery terminals. Link to comment Share on other sites More sharing options...
SteelTownStang Posted December 6, 2010 Report Share Posted December 6, 2010 I just clip mine to the battery terminals. +1... Link to comment Share on other sites More sharing options...
shel-b001 Posted December 6, 2010 Report Share Posted December 6, 2010 I use the permanent plug -in that attaches to the battery terminals & when not in use i tuck it between the fender & battery ,out of site. Link to comment Share on other sites More sharing options...
joebob948 Posted December 6, 2010 Report Share Posted December 6, 2010 I clip mine to the battery terminals-works great!!!!!!! BTW what part of Pa are you from? Link to comment Share on other sites More sharing options...
SPRSNK Posted December 6, 2010 Report Share Posted December 6, 2010 Battery Terminals here too. Link to comment Share on other sites More sharing options...
dffej51 Posted December 7, 2010 Author Report Share Posted December 7, 2010 I clip mine to the battery terminals-works great!!!!!!! BTW what part of Pa are you from? I am in the Pottstown area. Where are you? Link to comment Share on other sites More sharing options...
joebob948 Posted December 7, 2010 Report Share Posted December 7, 2010 I'm from the Scranton/Wilkes-Barre area Link to comment Share on other sites More sharing options...
dffej51 Posted December 19, 2010 Author Report Share Posted December 19, 2010 I clip mine to the battery terminals-works great!!!!!!! BTW what part of Pa are you from? Ok I just tried to hook up my battery tender and ran into an issue. With my previously owned Corvette there was a lot of clearance on the terninals to hook up the cable clips from the tender. On the Shelby, the regular battery cables cover 99% of the battery terminals and I can only barely get one prong of each battery tendor cable onto the terminals and that is if I lay the clips flat. Any suggestions? I definitely don't want to disconnect the regular battery cables from the battery. Thanks. Link to comment Share on other sites More sharing options...
coldfingers Posted December 19, 2010 Report Share Posted December 19, 2010 Ok I just tried to hook up my battery tender and ran into an issue. With my previously owned Corvette there was a lot of clearance on the terninals to hook up the cable clips from the tender. On the Shelby, the regular battery cables cover 99% of the battery terminals and I can only barely get one prong of each battery tendor cable onto the terminals and that is if I lay the clips flat. Any suggestions? I definitely don't want to disconnect the regular battery cables from the battery. Thanks. I just attach mine to the bolts that hold the clamps tight to the terminals, does the same thing and they are smaller so its easy to attach them there. Hope this helps Coldfingers Link to comment Share on other sites More sharing options...
Ezareth Posted December 20, 2010 Report Share Posted December 20, 2010 So if you plan on starting up and idling your Shelby every month through the winter do you need to use a battery tender? Link to comment Share on other sites More sharing options...
Torch40 Posted December 20, 2010 Report Share Posted December 20, 2010 So if you plan on starting up and idling your Shelby every month through the winter do you need to use a battery tender? I would, I've always found batteries last longer if a full charge is maintained. Link to comment Share on other sites More sharing options...
Doug_GT350 Posted December 20, 2010 Report Share Posted December 20, 2010 Might be a little hard to see, but I wired a two prong (male/female) direct to the battery. Just plug the tender in.... Link to comment Share on other sites More sharing options...
Joe G Posted December 20, 2010 Report Share Posted December 20, 2010 So if you plan on starting up and idling your Shelby every month through the winter do you need to use a battery tender? Yes. Just letting the engine idle will not keep the battery charged. In fact, if you're not going to run the engine up to full operating temps, it's not worth even starting it as you're doing more harm than good. If you don't get the temp up, you're not getting it hot enough to burn off the condensation in the oil. Best advice - put the tender on, cover the car, and leave it until spring when you can get it out and run it hard. Link to comment Share on other sites More sharing options...
