fatboy Posted December 3, 2010 Report Share Posted December 3, 2010 i have stock rims and tires. seems like i'm always puting air in them more often than my truck's tires. do low profile tires like on these shelbys require more frequent refilling? noticed my left front is lower than the rest but all need some air. my car does sit alot too. regarding the air leak in my right rear this past summer, that was fixed and the tire is still holding air. but, as i said, now i noticed left front is lower than others. i aired all of them to recomended presure a month ago. how often do any of u have to add air to them? Link to comment Share on other sites More sharing options...
csm198 Posted December 3, 2010 Report Share Posted December 3, 2010 i have stock rims and tires. seems like i'm always puting air in them more often than my truck's tires. do low profile tires like on these shelbys require more frequent refilling? noticed my left front is lower than the rest but all need some air. my car does sit alot too. regarding the air leak in my right rear this past summer, that was fixed and the tire is still holding air. but, as i said, now i noticed left front is lower than others. i aired all of them to recomended presure a month ago. how often do any of u have to add air to them? I am no expert but did a little research and one thing is that tires are porous and leak air continually. I also have problems when I let my car sit. Link to comment Share on other sites More sharing options...
rush_junky Posted December 4, 2010 Report Share Posted December 4, 2010 The Eagle F1 Supercar tires seem to require air more frequently than the stock tires. The Supercars are much better tires however. Link to comment Share on other sites More sharing options...
Orion Posted December 5, 2010 Report Share Posted December 5, 2010 I have my stock tires on my 2008 and need to check the tire pressure about once a month. They usually require some air. More so than with my 2005 GT. Link to comment Share on other sites More sharing options...
ilmor Posted December 5, 2010 Report Share Posted December 5, 2010 Tires normally lose 1 lb. per month. If outside temperatures drop considerably the "loss" will be greater. Keep in mind that there was also a TSB or recall re: the valve stems on our cars. The valve stems sometimes crack. You may want to check your valve stems as well, just in case. Link to comment Share on other sites More sharing options...
gene64cobra Posted December 5, 2010 Report Share Posted December 5, 2010 always the same problem here. i guess i need to drive them more.. Link to comment Share on other sites More sharing options...
fatboy Posted December 9, 2010 Author Report Share Posted December 9, 2010 well my left front was low because of a nail in it..... go figure. the rest were accually holdin air pretty well. thats 2nd time this year i get a nail. same goes with my tundra only it was last year when it was pickin up nails with it. everyone including me in the neighborhood got roofwork done due to bad hail storm 2 years ago. i'm guessin im runnin over roofin staples or somethin. i dont know. for 10 years though i have bad luck runnin over crap. 5 years ago i was in my tundra goin to work (i work nights so its dark) and i ran over a chunk of aluminum and ripped a gash in my tire. had to pull over quick and change it. had to replace it because it was too big of a gash. so i ended up gettin a new tire, but the rest were already half worn LOL. (had road hazard warrantee at least) lucky 1381 Link to comment Share on other sites More sharing options...
barricade111 Posted January 14, 2011 Report Share Posted January 14, 2011 wow i have this same problem...my front driverside tires need air every so often...my wife jokes saying im eating too much and my weight is the cause of it...but now i have proof it isnt my weight and can go back to eating in n out burgers.. :happy feet: Link to comment Share on other sites More sharing options...
alyupe11 Posted January 22, 2011 Report Share Posted January 22, 2011 I had the same problem for several months....While filling the left front tire I noticed the valve stem leaking. I took the car to Americas Tire for inspection and replacement.. Three of the four were cracked or cracking. I replaced all four added the road hazard and $78.00 later no more issues. I did this in August and to date (this morning) tires are still holding 32psi. Link to comment Share on other sites More sharing options...
