ShelbyEra08 Posted November 30, 2010 Report Share Posted November 30, 2010 Just curious, would of anyone rather have the 1970 Square exhaust type tips compared to the new one, on the new 350 I think it would have a better flow on the rear with square tips. Link to comment Share on other sites More sharing options...
tony356 Posted November 30, 2010 Report Share Posted November 30, 2010 Just curious, would of anyone rather have the 1970 Square exhaust type tips compared to the new one, on the new 350 I think it would have a better flow on the rear with square tips. no me, i love the round ......... and the sound!! Link to comment Share on other sites More sharing options...
Torch40 Posted November 30, 2010 Report Share Posted November 30, 2010 No Link to comment Share on other sites More sharing options...
DubbsFaris Posted December 1, 2010 Report Share Posted December 1, 2010 No, I think it would be even more of a problem when one tip sags. You would spot a square tip going out of alignment in a second. Link to comment Share on other sites More sharing options...
mywickedshelby Posted December 1, 2010 Report Share Posted December 1, 2010 No, I think it would be even more of a problem when one tip sags. You would spot a square tip going out of alignment in a second. its pretty easy to spot with the round ones too! Link to comment Share on other sites More sharing options...
shel-b001 Posted December 1, 2010 Report Share Posted December 1, 2010 No +1 Link to comment Share on other sites More sharing options...
BIKEBOY Posted December 3, 2010 Report Share Posted December 3, 2010 No, I think it would be even more of a problem when one tip sags. You would spot a square tip going out of alignment in a second. Good point, which leads to the question...why is the left one sagging , even in the build shop? The vid on the USA Today post that Roger put up, shows a 350 on the lift that has the rear seemingly done, and it's left tip sags too??? Is this a BORLA issue? Link to comment Share on other sites More sharing options...
Venom4U Posted December 4, 2010 Report Share Posted December 4, 2010 Good point, which leads to the question...why is the left one sagging , even in the build shop? The vid on the USA Today post that Roger put up, shows a 350 on the lift that has the rear seemingly done, and it's left tip sags too??? Is this a BORLA issue? Does anyone know why this happens? Is Shelby looking into this? I'm sure it's a minor fix. I didn't even get my car yet and it looks like I have my first repair. Link to comment Share on other sites More sharing options...
DubbsFaris Posted December 4, 2010 Report Share Posted December 4, 2010 A few of the exhaust pipes they are getting from Borla are just a bit too large. (like a couple mm) Since it is stainless steel, they cant be clamped tight if the tolerance is just slightly off. Shelby has a fix for it, but my fix was a simple tack weld. Seems to have corrected my problem, and can just be ground off if I have to remove or readjust for some reason. Apparently, they got a new clamp to correct the problem for future builds. Its a process when you design something unique like this. Link to comment Share on other sites More sharing options...
BIKEBOY Posted December 4, 2010 Report Share Posted December 4, 2010 A few of the exhaust pipes they are getting from Borla are just a bit too large. (like a couple mm) Since it is stainless steel, they cant be clamped tight if the tolerance is just slightly off. Shelby has a fix for it, but my fix was a simple tack weld. Seems to have corrected my problem, and can just be ground off if I have to remove or readjust for some reason. Apparently, they got a new clamp to correct the problem for future builds. Its a process when you design something unique like this. Thanks for the clarification Warren. Link to comment Share on other sites More sharing options...
