bdaztrk Posted November 23, 2010 Report Share Posted November 23, 2010 Checking to see if anyone has had this problem before.. 2011 model When the fuel gauge gets to half a tank the needle drops all the way to empty and it says 0 miles to go. The first time it happened it went to a gas station and left the key on to watch the gauge and after 2 gallons it went back the 3/4 tank. So I thought the tank lever might have just got stuck Today i was 7 miles from a station and it hit half a tank and showed like 125 miles or so until empty and then it did it again went to empty so i thought it had plenty of fuel but 3 miles down the road it went to bucking and backfiring like no fuel, It made it to the station doing that about got rearended, put 2 gallons in it again and went back to 3/4 tank and runs fine..Went to ford place cause i had a check engine light now and they said sensor and fuel rail pressure, so even if there is that much fuel in tank would the car still act like its empty and they said it could be pump issue also. Just checking to see other thoughts before they do the whole computer check point test that they said would take all day Quote Link to comment Share on other sites More sharing options...
bdaztrk Posted November 23, 2010 Author Report Share Posted November 23, 2010 (edited) Also the other day just to check to see if fuel gauge was right it was at almost half and i went to fill up and it only to a few gallons to kick off the pump so i know the gauge is right and it has a half a tank when this starts showing E and no miles left Edited November 23, 2010 by bdaztrk Quote Link to comment Share on other sites More sharing options...
MichaelP Posted November 23, 2010 Report Share Posted November 23, 2010 Checking to see if anyone has had this problem before.. 2011 model When the fuel gauge gets to half a tank the needle drops all the way to empty and it says 0 miles to go. The first time it happened it went to a gas station and left the key on to watch the gauge and after 2 gallons it went back the 3/4 tank. So I thought the tank lever might have just got stuck Today i was 7 miles from a station and it hit half a tank and showed like 125 miles or so until empty and then it did it again went to empty so i thought it had plenty of fuel but 3 miles down the road it went to bucking and backfiring like no fuel, It made it to the station doing that about got rearended, put 2 gallons in it again and went back to 3/4 tank and runs fine..Went to ford place cause i had a check engine light now and they said sensor and fuel rail pressure, so even if there is that much fuel in tank would the car still act like its empty and they said it could be pump issue also. Just checking to see other thoughts before they do the whole computer check point test that they said would take all day This was an issue with a few other members and their 2010's.. I dont think it was a big deal to fix... M. Quote Link to comment Share on other sites More sharing options...
bdaztrk Posted November 23, 2010 Author Report Share Posted November 23, 2010 (edited) Thanks Was this posted so i could do a search and see what fixed the problem Just didnt know the way of looking up that issue Edited November 23, 2010 by bdaztrk Quote Link to comment Share on other sites More sharing options...
MichaelP Posted November 23, 2010 Report Share Posted November 23, 2010 (edited) Thanks Was this posted so i could do a search and see what fixed the problem Just didnt know the way of looking up that issue I believe so...I think Fall of 2009...that is when I started reading this forum.. M. Edited November 23, 2010 by MichaelP Quote Link to comment Share on other sites More sharing options...
Torched10 Posted November 23, 2010 Report Share Posted November 23, 2010 try this link http://www.teamshelby.com/forums/index.php?/topic/50224-ran-out-of-gas/page__p__841767__hl__gas+tank__fromsearch__1#entry841767 new fule pump did it for him Quote Link to comment Share on other sites More sharing options...
bdaztrk Posted November 23, 2010 Author Report Share Posted November 23, 2010 Ford place said same thing, they will replace the whole fuel pump system. There was a bulletin on it for mustangs v6 and 5.0 no shelby showed up as a problem but the write up on the problem was the same so they ordered it Quote Link to comment Share on other sites More sharing options...
meshoooo Posted November 23, 2010 Report Share Posted November 23, 2010 Ford place said same thing, they will replace the whole fuel pump system. There was a bulletin on it for mustangs v6 and 5.0 no shelby showed up as a problem but the write up on the problem was the same so they ordered it No issue here ... Quote Link to comment Share on other sites More sharing options...
