Grabber Posted November 19, 2010 Report Share Posted November 19, 2010 A friend of mine recieved this message. Apparently it's just a heads up because there is no TSB on it. 2011 MUSTANGS EQUIPPED WITH MT82 MANUAL TRANSMISSION - EXPERIENCING VARIOUS CLUTCH SYMPTOMS 2011 MUSTANGS EQUIPPED WITH MT82 MANUAL TRANSMISSION MAY EXPERIENCE DIFFICULTY SHIFTING INTO REVERSE AND 1ST GEAR, LOW CLUTCH PEDAL RESERVE OR CLUTCH PEDAL FEELING VERY LIGHT. POSSIBLE CAUSE COULD BE LOOSE CLUTCH PRESSURE PLATE BOLTS. REFER TO WORKSHOP MANUAL SECTION 308-01 (CLUTCH REMOVAL AND INSTALLATION FOR APPROPRIATE ENGINE APPLICATION). CLEAN THREAD MATERIAL FROM FLYWHEEL BOLT HOLES WITH APPROPRIATE NON-OIL BASED SOLVENT. DURING INSTALLATION BE SURE TO INSTALL NEW PRESSURE PLATE BOLTS (W715869-S439) AND TIGHTEN ONE TURN AT A TIME IN A STAR PATTERN UNTIL ALL BOLTS REACH A NEW TORQUE OF 63NM (46 LBFT). TIGHTEN EACH BOLT AN ADDITIONAL 60 DEGREES IN A STAR PATTERN. USE APPROPRIATE LABOR TIMES FOR REPAIR. WSM IS BEING UPDATED Link to comment Share on other sites More sharing options...
