Grabber Posted November 6, 2010 Report Share Posted November 6, 2010 The jacking and lifting points have not changed. Here's the new Ford PDF file on the points to use: 2011 Jacking and lifting.pdf 2011 Jacking and lifting.pdf Quote Link to comment Share on other sites More sharing options...
bigsnake Posted November 6, 2010 Report Share Posted November 6, 2010 Thanks for the info, I put in my documents folder. Quote Link to comment Share on other sites More sharing options...
BOOGIEDOWN GT500 Posted November 8, 2010 Report Share Posted November 8, 2010 (edited) thank you. Edited November 9, 2010 by BOOGIEDOWN GT500 Quote Link to comment Share on other sites More sharing options...
Grabber Posted December 31, 2010 Author Report Share Posted December 31, 2010 Your welcome. Quote Link to comment Share on other sites More sharing options...
DaFreak Posted January 2, 2011 Report Share Posted January 2, 2011 The jacking and lifting points have not changed. Here's the new Ford PDF file on the points to use: 2011 Jacking and lifting.pdf Hi Grabber, Has Ford every posted pics of jacking and the use of jackstands? It would be awesome to see how to use a jack and jackstand together. I do find it a but curious that they don't mention the pinch welds at all. DaFreak. Quote Link to comment Share on other sites More sharing options...
Grabber Posted January 2, 2011 Author Report Share Posted January 2, 2011 Hi Grabber, Has Ford every posted pics of jacking and the use of jackstands? It would be awesome to see how to use a jack and jackstand together. I do find it a but curious that they don't mention the pinch welds at all. DaFreak. Ford circled the pinch welds in the PDF file. I have another document on the jack stand points I will round up for you. Quote Link to comment Share on other sites More sharing options...
Grabber Posted January 2, 2011 Author Report Share Posted January 2, 2011 Look at the PDF file and go to page 100-06A-2 and the drawing "Vehicle Lift points - Mustang" Vehicle_Lift_Points__S7Z06A12.pdf Here's a pic of the back of my car showing the pinch weld point that you can use a sissor jack on and I put a red dot on the frame rail point where you can place the jack stand. Here is a pic of the front of my car and take note of where I have the red dot on the front frame rail. You can place the jack stand there. Here's a couple more pinch weld point location Ford drawings Vehicle_Lift_Points__S7Z06A12.pdf Quote Link to comment Share on other sites More sharing options...
devans101 Posted January 2, 2011 Report Share Posted January 2, 2011 Good post for a sticky.... Quote Link to comment Share on other sites More sharing options...
davegt500 Posted January 2, 2011 Report Share Posted January 2, 2011 (edited) Aha! So thats the rocker notch referred to. Thanks Grabber! Now, with 733 miles racked up, time to mess around with the "Launch control" and see if that actually exists or not. 3200 rpm and quick release the clutch, keep the gas pedal floored and ignore any banging type noises from what I've read here and there. Should be a nice feature if it actually works! Edited January 2, 2011 by davegt500 Quote Link to comment Share on other sites More sharing options...
DaFreak Posted January 2, 2011 Report Share Posted January 2, 2011 Beautiful. Thanks Grabber! DaFreak Quote Link to comment Share on other sites More sharing options...
Grabber Posted January 2, 2011 Author Report Share Posted January 2, 2011 Good post for a sticky.... OK....consider it done. Quote Link to comment Share on other sites More sharing options...
cwa2wa2011 Posted January 9, 2011 Report Share Posted January 9, 2011 Great post! I appreciate the pics! Quote Link to comment Share on other sites More sharing options...
jerseygator Posted January 12, 2011 Report Share Posted January 12, 2011 Good post for a sticky.... +1 Quote Link to comment Share on other sites More sharing options...
jerseygator Posted January 18, 2011 Report Share Posted January 18, 2011 Just put mine up on the jack stands. How solid is it? I had some scary thouhgts while I was working under it last night. Quote Link to comment Share on other sites More sharing options...
2010KB Posted January 23, 2011 Report Share Posted January 23, 2011 The jacking and lifting points have not changed. Here's the new Ford PDF file on the points to use: 2011 Jacking and lifting.pdf Does anyone know if FORD has revised the jacking points for the Mustang? Today on SPEED there was a special on the new BOSS 302 and 302R and they had several shots of the cars being jacked midway on the car between the front and rear wheels. Granted there is more weight on the 2010 Shelby front end, and the 2011 is lighter with the aluminum block, however I would not think that the BOSS version is that much lighter that would allow jacking in the center of the rocker. They did this on the R that has the cross bracing in the rear seat delete, and they did it on the regular BOSS 302. Thoughts or comments? Quote Link to comment Share on other sites More sharing options...
32V-SVT Posted February 9, 2011 Report Share Posted February 9, 2011 Great post Grabber, verifies what I've been using... Thanks! Quote Link to comment Share on other sites More sharing options...
Boidster Posted March 2, 2012 Report Share Posted March 2, 2012 (edited) Is it still thread necromancy if the thread is a sticky? Anyway, what about floor jacks? I didn't think I'd take the scissor jack out of the trunk when I've got several sizes of floor jack around. I would assume I could position it just rearward of the front red jackstand dot (or just forward of the rear jackstand dot). Bad assumption? My floor jacks don't have an adapter for pinch welds, but should I just position the cup at that point anyway (taking care that the edge of the weld is sitting flush in the cup, not catching on either side of the weld)? I assume the idea is to have the car resting on 3 points, so the entire weight of the right or left side isn't resting on a mid-body jack point. On the F-150 I just pick a solid point on the frame and get jackin'. Edited March 2, 2012 by Boidster Quote Link to comment Share on other sites More sharing options...
AndyGJ Posted July 22, 2012 Report Share Posted July 22, 2012 I will have to see how well my new Low Profile Floor Jack works on the SGT frame rails....great info. Andy. Quote Link to comment Share on other sites More sharing options...
ShelbyGT5HUN Posted December 22, 2014 Report Share Posted December 22, 2014 Hey Grabber, I noticed you put something between the jack and the pinch welds to protect the paint, what did you use? Thanks Quote Link to comment Share on other sites More sharing options...
Grabber Posted December 23, 2014 Author Report Share Posted December 23, 2014 Hey Grabber, I noticed you put something between the jack and the pinch welds to protect the paint, what did you use? Thanks Home depot has the heavy duty felt pads with adhesive on one side. You can stick them on your jack. They sell it in precut pads or small sheets that you can cut to the size you want. Here is the link to the product. I stuck them to the top of the jack. http://www.homedepot.com/p/Shepherd-1-in-Heavy-Duty-Self-Adhesive-Felt-Pads-48-per-Pack-9972/100392358 Quote Link to comment Share on other sites More sharing options...
olisickstang Posted November 8, 2015 Report Share Posted November 8, 2015 Thanks you very much Grabber ! Quote Link to comment Share on other sites More sharing options...
