buzbrown Posted November 1, 2010 Report Share Posted November 1, 2010 I own a '68 GT500KR convertible that has been restored. In a recent transport, the radio antenna mast was broken. I am trying to determine the correct antenna. The antenna on the car which, I suppose was origional, has about a 4 or 5" base in the trunk & the antenna cable comes out the bottom & runs the full way from the trunk to the radio. See picture attached. I have been told this is both correct and not correct. I have been told it came with an antenna that has about a 12" tube inside the trunk & the cable is attached to the side of the tube & is called a "pm300". See picture attached. I am very confused. I don't know which is correct. Neither one has the complete cable to the radio. They both have an extension cable. Can anyone out there help me with this? I don't want to buy the wrong antenna as both are quite expensive. Thanks for your help! Link to comment Share on other sites More sharing options...
ctann Posted November 2, 2010 Report Share Posted November 2, 2010 I own a '68 GT500KR convertible that has been restored. In a recent transport, the radio antenna mast was broken. I am trying to determine the correct antenna. The antenna on the car which, I suppose was origional, has about a 4 or 5" base in the trunk & the antenna cable comes out the bottom & runs the full way from the trunk to the radio. See picture attached. I have been told this is both correct and not correct. I have been told it came with an antenna that has about a 12" tube inside the trunk & the cable is attached to the side of the tube & is called a "pm300". See picture attached. I am very confused. I don't know which is correct. Neither one has the complete cable to the radio. They both have an extension cable. Can anyone out there help me with this? I don't want to buy the wrong antenna as both are quite expensive. Thanks for your help! I believe that the antennas were actually installed by the dealers, so it is probably possible that there is some variety. I'll try and snap and snap a photo of mine, I have both my original, and a replacement on the car. Mine does have a relatively short cable, and plugs into an extension in the trunk, up by the wheel well. I know you should also look for a cable with a large grommet attached - although the grommet is not used in the KR application. Pete Disher has a picture of the "radio kit" on his website: http://www.thecoralsnake.com/Electrical.HTML - I'm sure if you contact him, he will give you a much better answer than I could. Regards, Chris. Link to comment Share on other sites More sharing options...
Cali_KR Posted November 2, 2010 Report Share Posted November 2, 2010 +1 on Pete Disher, he is the authority on all things '68. And as Chris mentioned, antennas where dealer installed, so there is a history of inconsistencies Link to comment Share on other sites More sharing options...
Naa-V-Doc Posted November 13, 2010 Report Share Posted November 13, 2010 What a nice problem to have!!! I you. - Doc ---------------------------------------------------------------------------------------------------------------------------------------------------------------- I own a '68 GT500KR convertible that has been restored. In a recent transport, the radio antenna mast was broken. I am trying to determine the correct antenna. The antenna on the car which, I suppose was origional, has about a 4 or 5" base in the trunk & the antenna cable comes out the bottom & runs the full way from the trunk to the radio. See picture attached. I have been told this is both correct and not correct. I have been told it came with an antenna that has about a 12" tube inside the trunk & the cable is attached to the side of the tube & is called a "pm300". See picture attached. I am very confused. I don't know which is correct. Neither one has the complete cable to the radio. They both have an extension cable. Can anyone out there help me with this? I don't want to buy the wrong antenna as both are quite expensive. Thanks for your help! Link to comment Share on other sites More sharing options...
