SGT/SC#0471 Posted November 11, 2010 Report Share Posted November 11, 2010 I think on my 07 I am going to run some Moroso or Sparco all aluminum polished plates and pop rivet them in to match the hood scoop rivits...they are flat and not billet so they will match the SA originals and look good and possibly never corrode....body shop guy told me that there have been other corrosion issues with Ford without hood pins on aluminum body parts....I have no idea...but I figure if its all aluminum parts that would rule out galvanic corrosion. Link to comment Share on other sites More sharing options...
SGT/SC#0471 Posted November 11, 2010 Report Share Posted November 11, 2010 Interestingly, I forgot to add the pins are rusting pretty good as well on my car and the pin mount plates are very rusty with the coating gone...I am going to powdercoat these and run aluminum pins as well.... Link to comment Share on other sites More sharing options...
springer Posted November 12, 2010 Report Share Posted November 12, 2010 Number 8 screws work fine. I don't have a clue what the metric equivalence is, but if you use #8 screws, they will work. So, what was the bet. Link to comment Share on other sites More sharing options...
JeffIsHereToo Posted November 12, 2010 Report Share Posted November 12, 2010 I think on my 07 I am going to run some Moroso or Sparco all aluminum polished plates and pop rivet them in to match the hood scoop rivits...they are flat and not billet so they will match the SA originals and look good and possibly never corrode....body shop guy told me that there have been other corrosion issues with Ford without hood pins on aluminum body parts....I have no idea...but I figure if its all aluminum parts that would rule out galvanic corrosion. He is correct. There is a TSB for Mustang hoods having this issue due to contamination under the paint. Link to comment Share on other sites More sharing options...
SGT/SC#0471 Posted November 30, 2010 Report Share Posted November 30, 2010 Number 8 screws work fine. I don't have a clue what the metric equivalence is, but if you use #8 screws, they will work. So, what was the bet. Ok I'll eat my hat... I am going all aluminum flat plates and pop rivets...screw the stainless... Link to comment Share on other sites More sharing options...
