Just Purchased Shelby
Hello there Team Shelby,
just purchased a 2007 Shelby Gt white one,
the car is all orginal stock as can be
with 1000 miles, I assume it has orginal hood pins etc ( do they need to be changed ? )
what does everyone recommend other than a oil change as it is prob orginal ??
what oil and filter ??
what are some of the must have options that I should do ?
would def like to get this car up to speed which has been locked away for 3 years
Thanks
Mark
Yup, Welcome to the Insanity! Don't even go there on what oil to use...it's a matter of preference...just as long as it meets Ford requirements...Like FordRocks1, I use Mobil 1 5W20 Full Synthetic and FL820 Motorcraft filter every 5,000 miles...I also add Z-Max fuel and oil additive at every oil change...
Mods, just start building a list and go from there...to each his own...
Enjoy the car, drive it like you stole it and have fun!
Carl
Top of the list ought to be a decent set of tires. Beyond that, the list is potentially endless. If I was starting from scratch, I'd do tires, brakes, minor suspension upgrades, supercharger, in that order. Good luck and welcome.
No. 1 - Get Carrol Shelby's autograph on your airbag cover.
I agree w/ Kahmann, except at only 3 years old I wouldn't worry about the tires just yet, although if you have the dough, sure, go ahead and upgrade them, along with some lightweight wheels unless you want to retain the original bullets (as I do). The stock tires are fine, and good tires, but being of the all-season variety their are many more grippy options. My plan has just been to naturally wear out my original BFG's, to get my money's worth out of them, and then move onto whatever the preferred tire is at that time.
I started w/ the autographn then the brake upgrades (drilled & slotted rotors, s/s brake lines), then did the rear lower control arms and adj. panhard bar. The next things I would like to do are the aluminum driveshaft and a performance tune (such as Brenspeed).
Currently I'm taking care of my rusty butt (see my other topic)....
Congrats on your new SGT and welcome to the forums!!
Can someone tell me how the dash plate thing comes off so I can send it
out for a signature, I have the IUP package
Thanks
MArk
Disconnect the battery, then turn the ignition on for 5 minutes to completely void the Can bus of any voltage
Remove the glove box door
Remove two screws holding airbag assembly to the dash frame.
Unplug the electrical connector from the rear of the airbag assembly
relieve the pressure from the lower attachment serrated clips on the panel where it meets the dash and the cover with airbag will pop out
Gently pry airbag retaining clips from the airbag cover.
The airbag can be reinstalled and made operational while you are waiting for the autograph.
What mods to add? Boy, that's a loaded question! You'll see it all here, from certain people who SWORE they would never mod, to others who never seem to stop!
I think rule one is to mod to YOUR heart's content! If you think it's right, then go for it - because it is YOUR car!
I've seen a lot of SGTs here (and elsewhere) and tried to keep the appearance mods to a minimum, only putting things on that suited my tastes or enhanced the overall performance of the car.
Rule two would be to consider mods that are reversible if your looking at the "collectible" value of the SGT, but face it, these cars probably aren't going to be valuable until most of us are dead and gone, so see rule one!
Have fun and drive that sucker!
Oh, and White is the fastest color!
Sam
Here are a few more ideas. I copied and pasted my current 'mod list' from my profile page. Happy modding! :shift:
Powerplant MMR 5.0 Stroker 950 Street Mod Motor
ARP 2000 fasteners - main caps/heads/rods/balancer/flywheel
ATI super street crank pulley 8-rib 10% overdrive
ATP Turbo vented oil catch can
Clevite 77 H-Series tri-metal main and rod bearings
Comp XFI SPR stage 3 cams
Comp beehive valve springs
Comp cam phaser limiters
Comp titanium valve spring retainers
FelPro extreme duty head gaskets
FRPP aluminum block
K&N crankcase breathers
Kellogg 8 bolt forged stroker steel racing crankshaft
Manley 4340 forged H-beam rods
Manley forged pistons +.020" - 9.0:1CR
Manley oversized forged stainless steel intake/exhaust valves
MMR SVT oil pump with teflon coated thrust plate
Moroso black powdercoated aluminum 7 quart oil pan
Power Heads stage 3 port/polish cylinder heads
Royal Purple 5W30 synthetic oil
Royal Purple synthetic power steering fluid
Sealed Power piston rings
Steeda heavy duty belt tensioner
Thump RRR Racing 90mm billet idler pulley
Thump RRR Racing 76mm billet tensioner idler
TSS billet oil pump gears
Intake
DiabloSport MAF.ia interface adapter
FRPP intake manifold
FRPP IAT sensor relocation kit
HPX slot-style MAF sensor
Paxton Novi 1200SL satin supercharger
Vortech 3.33" supercharger pulley
Vortech Maxflow race blowoff valve
Fuel
Ashcroft 100# liquid filled rail mounted fuel pressure gauge
FRPP GT500 dual fuel pumps
FRPP fuel injector adapter kit
Metco natural finish high flow fuel rails
SiemensDeka 63# flow matched fuel injectors
Exhaust
JetHot 1700* extreme sterling silver coating
Kooks long tube headers - 1 3/4" primary x 3" collector
Kooks x-pipe 3" x 2 1/2"
Magnaflow 3" high flow cats
Magnaflow muffler deletes
Stage 8 locking header bolts
Electrical
FRPP zero degree spark plugs
Odyssey PC1700 battery
Road Rage 200 amp circuit breaker
SCT Livewire
Summit Racing ignition coils
Taylor aluminum battery box trunk relocation kit
VMP Tuning custom 91 octane tune
Vendicated Tuning custom race tune
Cooling
EMP Stewart high performance water pump
Fel-Pro thermostat o-ring
Moroso black powdercoated aluminum coolant reservoir
RedLine Water Wetter coolant additive
Reische Performance 170* thermostat
Paxton air-to-air intercooler
Shelby high performance radiator
Snow Performance 'Stage 3 Boost Cooler' meth injection
Snow Performance solenoid upgrade kit
Summit Racing black in-line radiator hose filler w/ FRPP cap
Suspension Griggs Racing GR40ST rear suspension
FRPP front dampers
Griggs Racing road race adjustable rear lower control arms
Griggs Racing torque arm
Griggs Racing severe duty adjustable panhard bar
Griggs Racing axle & shock support bracket kits
Griggs Racing heim joints throughout
Koni rear coil-overs w/ street shocks & 225# springs
Prothane 1/2" lowering heavy duty motor mounts
Drivetrain
FRPP 4.10 gears
FRPP aluminum flywheel
FRPP roller pilot bearing
RedLine 75W140 synthetic gear oil
RedLine D4ATF synthetic trans fluid
Spec Stage 3+ clutch
TA differential stud kit
Wheels
FRPP center caps
Front - FRPP GT500 wheels 18" x 9.5"
Rear - FRPP GT500 wheels 18" x 10.5" (Weldcraft widened)
Tires
Front - Toyo RA1 275/35ZR18
Rear - Toyo RA1 305/35ZR18
Safety
FRPP tow hook with custom mounting bracket
Griggs Racing bolt in roll bar
H3R halon chrome 2.5 lb. fire extinguisher
H3R billet fire extinguisher roll bar mounting bracket/clamp
Brakes
Baer Decelarotor slotted/cross drilled rear rotors
FRPP Brembo front calipers/rotors
G2 red high temp caliper paint
Goodridge stainless steel brake lines
Hawk HPS pads
Motul RBF 660
Stainless steel speed bleeder valves
Exterior Styling
Painted le mans stripes
Painted custom front fascia
Painted blue side mirrors
Silver pit stripes
Shelby Super Snake hood vents
Shelby Bash 'Bullrun' decals
Shelby aluminum quarter window covers
Shelby chrome lower grill
SGT faux gas cap emblem
HID headlights
35% black onyx tint
Griggs Racing windshield banner
Interior Styling
IUP black/charcoal
Autometer A-pillar gauge pod
Autometer Cobalt wideband A/F gauge
Autometer Cobalt electrical boost/vacuum gauge
Shelby headrest covers
SGT leather trim/silver stitch console lid
FRPP floor mats
SGT dead pedal
CS signed airbag cover
Snow Performance meth injection controller
Engine Bay Styling
ATP Turbo black silicone intercooler couplers
ATP Turbo red silicone vacuum hose
Matte black painted intercooler plumbing
Clampco T-bolt clamps
Shelby hood scoop - custom functional
Shelby American/Paxton retro engine bay plaque
Shelby engine cap set
Shelby fuse box cover
JLT carbon fiber radiator cover
Ford black powdercoated motor mount adapters
Ford black powdercoated timing cover
FRPP black powdercoated cam covers
FRPP strut tower brace
Steeda billet hood struts
Scott Drake billet underhood hardware
TurboHoses red silicone bypass valve hoses
