AlloyDropTop Posted October 4, 2010 Report Share Posted October 4, 2010 My car has had the front suspension apart and parts replaced about 4 times now looking for a thunking / clunking noise. I was under the front end and it seems like a plastic fenderwell part might be missing, that may have been forgotten during a reassembly. On the drivers side, a plastic part in the wheel well is right in front of the sway bar, seeming to be there to deflect air tword the brake, but on the passenge side, it doesn't exist. Can somebody post a picture of the passeger wheel well, with the tire / wheel removed, so I can see if this part is on your car, to verify I am missing it, or maybe it simply doesn't exist on the passenger side for some reason. I could only find a few pictures on the internet, and from the two I saw, this part may actually be drivers side specific for some reason, but a picture of somebody else's would verify I don't need to go get somebody to replace it. Link to comment Share on other sites More sharing options...
6-Speed Posted October 4, 2010 Report Share Posted October 4, 2010 Here are a couple from my archives. Link to comment Share on other sites More sharing options...
09 Red GT500 Posted October 4, 2010 Report Share Posted October 4, 2010 If that piece is the one I think you are talking about, it only exists on the driver's side. When I did my brake cooling ducts, the instructions pointed that piece out as needing to be removed. Link to comment Share on other sites More sharing options...
AlloyDropTop Posted October 4, 2010 Author Report Share Posted October 4, 2010 Excellant! Thanks for the help. For whatever reason it exists, it appears to be a driver side only part, and thus I am not missing it. Thanks! Link to comment Share on other sites More sharing options...
09TSpony Posted October 4, 2010 Report Share Posted October 4, 2010 Is it a one time thunk upon first starting the car and rolling forward? If so there is a thread on here advising that it has to do with a clutch pack or something related to the AC compressor. It is a loud thunk and you hear it from the drivers side of the car. Link to comment Share on other sites More sharing options...
AlloyDropTop Posted October 5, 2010 Author Report Share Posted October 5, 2010 Is it a one time thunk upon first starting the car and rolling forward? If so there is a thread on here advising that it has to do with a clutch pack or something related to the AC compressor. It is a loud thunk and you hear it from the drivers side of the car. The noise is more of a loose sound over low speed bumps. More like a sloppy strut mount, sloppy bushings, bad strut, bad ball joint, etc... Problem is everyone of those parts has been replaced. It is possible I am overly sensitive to this noise, but It seems like too much to me. Link to comment Share on other sites More sharing options...
6-Speed Posted October 5, 2010 Report Share Posted October 5, 2010 The noise is more of a loose sound over low speed bumps. More like a sloppy strut mount, sloppy bushings, bad strut, bad ball joint, etc... Problem is everyone of those parts has been replaced. It is possible I am overly sensitive to this noise, but It seems like too much to me. Did you have the front lower control arms replaced? There's a TSB on it ... TSB-09-24-16. Link to comment Share on other sites More sharing options...
