Mulanzo Posted September 29, 2010 Report Share Posted September 29, 2010 Hello.. I just recently finished installing the Shelby autographed passenger airbag cover and to do the install I needed to disconnect the battery so the bag didn't pop in my face. I had a full fuel tank at the time. When I reconnected the battery, the digital readout displayed the level on the tank as WAY higher than it normally should. Usually it says about 360-380 km to empty on a full tank and it was saying 480 km to empty on the full tank. The fuel gauge (the dial not the electronic readout) is normal. Has anyone experienced anything like this? Is this normal when you d/c the battery and then reconnect? I'm thinking it takes a few drives to recalibrate the sensor but I'm not sure if I should bring it in to get looked at... Link to comment Share on other sites More sharing options...
Burning Blue Star IV Posted September 29, 2010 Report Share Posted September 29, 2010 Hello.. I just recently finished installing the Shelby autographed passenger airbag cover and to do the install I needed to disconnect the battery so the bag didn't pop in my face. I had a full fuel tank at the time. When I reconnected the battery, the digital readout displayed the level on the tank as WAY higher than it normally should. Usually it says about 360-380 km to empty on a full tank and it was saying 480 km to empty on the full tank. The fuel gauge (the dial not the electronic readout) is normal. Has anyone experienced anything like this? Is this normal when you d/c the battery and then reconnect? I'm thinking it takes a few drives to recalibrate the sensor but I'm not sure if I should bring it in to get looked at... Mulanzo... It should eventually work itself back down to near accurate status. Depending on how much you drive the car it make take a long while. I briefly disconnected my battery and the same thing happened. I probably took at least a month to get back to normal. It should be fine. Link to comment Share on other sites More sharing options...
Mulanzo Posted September 29, 2010 Author Report Share Posted September 29, 2010 Thanks Blue! Always good with the helpful information you are! Link to comment Share on other sites More sharing options...
Burning Blue Star IV Posted September 29, 2010 Report Share Posted September 29, 2010 Thanks Blue! Always good with the helpful information you are! No problem. I too, thought something might be wrong after the same thing happened to mine. But I just had a feeling it would eventually work itself out. Link to comment Share on other sites More sharing options...
2010KonaBlueGT Posted September 30, 2010 Report Share Posted September 30, 2010 I'm thinking it takes a few drives to recalibrate the sensor but I'm not sure if I should bring it in to get looked at... The quick and easy fix is: Disconnect the Negative (-) terminal on your battery. Take the disconnected Negative (-) terminal and touch it to the Positive (+) terminal (that will discharge any capaciters). Leave it disconnected for a while, just to be sure any residual power is drained off. Reconnect the Negative(-) terminal to the battery post. WITHOUT TOUCHING ANYTHING ELSE, turn your ignition key to the "on" position (NOT "start"). Watch your gauge needles. They will all jump up, then they will all reset to their natural positions. TURN THE KEY OFF. Restart your car and let it idle for about 15 minutes WITHOUT TOUCHING ANYTHING (other than pushing in the clutch to start it). You may hear the idle change, get rough then smooth out, etc. DO NOT TOUCH THE GAS PEDAL. This will allow your PCM to relearn the adaptive strategy parameters. That *should* take care of your problem/s but now your windows won't "auto set". To reset your windows, push the switch to lower the window all the way down. Hold the switch in the "down" position for at least 10 seconds. Do the same for the Pass. side. Phill Link to comment Share on other sites More sharing options...
Mulanzo Posted September 30, 2010 Author Report Share Posted September 30, 2010 Thanks! I'll give it a shot tomorrow... I love this forum. Link to comment Share on other sites More sharing options...
