jrhsvt Posted September 26, 2010 Report Share Posted September 26, 2010 I want to go with 19x11 rims for my 2010 gt500. Does anyone know what offset/backspacing is required for this to work? I'm thinking of going with the Nitto Invo 325's. I know that it's a possibility that I may need to do some light trimming of the bumpstop; I just don't want the tire sticking out of the fender. I've read on here that people have done it, but I'm having trouble finding exactly which offset and backspacing to use. Link to comment Share on other sites More sharing options...
SVTpower Posted September 26, 2010 Report Share Posted September 26, 2010 pm sent Link to comment Share on other sites More sharing options...
frazierfreud Posted September 26, 2010 Report Share Posted September 26, 2010 i'm thinking my ideal setup at this point would be 19"x11.5" rims with nitto invo 345/30zr19 for rear and 19"x9.5 rims with nitto invo 285/35zr19 for front. i've seen people on ts run 335's in rear before. inflated tire height is right at 27" for both. just like you, will probably have to trim bump stop. traction with these cars is key. i would love to be able to get rid of the drag radials and have enough meat out back to get get traction with a 2nd gear romp! my car is totally set up for straight line at this point...have to start working on handling! anybody know if the invo 325 or 345 will keep the power to the road? Link to comment Share on other sites More sharing options...
jrhsvt Posted September 26, 2010 Author Report Share Posted September 26, 2010 link above is an interesting coversation regarding those with the super snake (comparable power as you) getting good traction in straight line and cornering by various suspension mods. Namely Griggs and FRPP, or various components of both. Link to comment Share on other sites More sharing options...
jrhsvt Posted September 26, 2010 Author Report Share Posted September 26, 2010 i'm thinking my ideal setup at this point would be 19"x11.5" rims with nitto invo 345/30zr19 for rear and 19"x9.5 rims with nitto invo 285/35zr19 for front. i've seen people on ts run 335's in rear before. inflated tire height is right at 27" for both. just like you, will probably have to trim bump stop. traction with these cars is key. i would love to be able to get rid of the drag radials and have enough meat out back to get get traction with a 2nd gear romp! my car is totally set up for straight line at this point...have to start working on handling! anybody know if the invo 325 or 345 will keep the power to the road? How did you determine what offset and backspacing to use in order to not have the tires stick out from under the back fenders? Or are you at that point yet? Link to comment Share on other sites More sharing options...
iamlightning03 Posted September 27, 2010 Report Share Posted September 27, 2010 These were recently installed on the rear of a vett at the shop while i was on a service call. Does anyone knom the width of a vett wheel. Oh by the way 325 goodyear f1s came off! If i can score a couple more wheels im calling weldcraft! Link to comment Share on other sites More sharing options...
Alexandros Posted September 27, 2010 Report Share Posted September 27, 2010 Those will look nice.... Link to comment Share on other sites More sharing options...
jrhsvt Posted September 27, 2010 Author Report Share Posted September 27, 2010 The C6 is "stock" Front wheel size: 18x8.5 offset: +56 mm Rear Wheel size: 19x10 offset: +79 mm and has a 285 wide tire. Hence my original question about offsets...I have a feeling it matters. Link to comment Share on other sites More sharing options...
frazierfreud Posted September 27, 2010 Report Share Posted September 27, 2010 How did you determine what offset and backspacing to use in order to not have the tires stick out from under the back fenders? Or are you at that point yet? i'm not at that point yet. however, a ts member has ccw sp500 18" rims...they are 11" wide with 52mm offset. i forget the thread, but i wrote down the info so i wouldn't forget it for possible future reference. i'm not sure how much difference, if any, it will make comparing an 18" rim to a 19" rim. Link to comment Share on other sites More sharing options...
frazierfreud Posted September 27, 2010 Report Share Posted September 27, 2010 These were recently installed on the rear of a vett at the shop while i was on a service call. Does anyone knom the width of a vett wheel. Oh by the way 325 goodyear f1s came off! If i can score a couple more wheels im calling weldcraft! very nice! Link to comment Share on other sites More sharing options...
frazierfreud Posted September 27, 2010 Report Share Posted September 27, 2010 link above is an interesting coversation regarding those with the super snake (comparable power as you) getting good traction in straight line and cornering by various suspension mods. Namely Griggs and FRPP, or various components of both. thanks Link to comment Share on other sites More sharing options...
blkGT500nCA Posted September 27, 2010 Report Share Posted September 27, 2010 How wide are the wheels that these 325's are going on? Link to comment Share on other sites More sharing options...
jrhsvt Posted September 28, 2010 Author Report Share Posted September 28, 2010 11'' wide. 19'' in diameter. Link to comment Share on other sites More sharing options...
fastfords Posted September 28, 2010 Report Share Posted September 28, 2010 That is the stock rear tire size of a Z06 or a Grand Sport. They come with 12" x 19" rear wheels. Link to comment Share on other sites More sharing options...
blkGT500nCA Posted September 28, 2010 Report Share Posted September 28, 2010 11'' wide. 19'' in diameter. yeah, I guess the title of the thread is 19 x 11. Link to comment Share on other sites More sharing options...
32V-SVT Posted September 28, 2010 Report Share Posted September 28, 2010 Hey what did that tire run ya? $$ Link to comment Share on other sites More sharing options...
jrhsvt Posted September 29, 2010 Author Report Share Posted September 29, 2010 price = $313 or so... Link to comment Share on other sites More sharing options...
