drspa Posted September 25, 2010 Report Share Posted September 25, 2010 On my 2010 supersnake the driveshaft has been making contact and the best I have been able to get for a answer is the aluminum drive shaft is larger and the frrp suspension is lower. I have researched a little and want to know if the Steeda adjusible upper control arm is the fix. Anyone have the same problem with there 750hp Shelbys, and if so can I get some advise. Thanks John Link to comment Share on other sites More sharing options...
dbackg Posted September 25, 2010 Report Share Posted September 25, 2010 Read this link: http://www.teamshelby.com/forums/index.php?app=core&module=search&do=user_activity&mid=11161&search_app=forums&userMode=content&sid=062dd2c138e7be19a00fc19b3ddae07c&st=100 I have the upgraded Shelby aluminum driveshaft on my SS. http://www.teamshelby.com/forums/index.php?/topic/57401-dbackgs-super-snake-vert-upgrades/ Raise and/or siffening the rear suspension seems like the only logical answer. My driveshaft still hits the body underside when I hit a good bump in the road. Link to comment Share on other sites More sharing options...
bchorney Posted September 25, 2010 Report Share Posted September 25, 2010 If I hit a big bump with passangers in the car my drive shaft will hit the tunnel as well. I have the Shelby - Eibach set up. Cheers Brett Link to comment Share on other sites More sharing options...
woody81 Posted September 27, 2010 Report Share Posted September 27, 2010 On my 2010 supersnake the driveshaft has been making contact and the best I have been able to get for a answer is the aluminum drive shaft is larger and the frrp suspension is lower. I have researched a little and want to know if the Steeda adjusible upper control arm is the fix. Anyone have the same problem with there 750hp Shelbys, and if so can I get some advise. Thanks John I installed the BMR anti-wheel hop kit on my SS and that alone stopped the drive shaft from hitting the tunnel. I can drive hard, on bumpy roads, with people in the back seat and the driveshaft has never hit the tunnel again. Install this kit and you will be pleased. Link to comment Share on other sites More sharing options...
dbackg Posted September 27, 2010 Report Share Posted September 27, 2010 I believe Alex installed: Steeda part # 555-4105 on my girl. Steeda Adjustible rear upper 3rd link. Adjustable rear upper 3rd link: This part allows the ability to set pinion angle and eliminate the torque deflection of the factory piece. Direct replacement for factory rear upper 3rd link. 1. 555-4105 - Steeda Adjustable Upper Control Arm - Street - $188.95 2. 555-4107 - Competition Upgrade Kit For Street Upper Control Arm - $204.70 3. 555-4108 - Street Upgrade Kit For Comp/Street Upper - $204.70 http://www.steeda.com/store/steeda-adjustable-upper-control-arm-for-2005-thru-2010-ford-mustang.html Another Steeda upper. 555-4096 - Steeda Upper Control Arm - Lowered Vehicle - $136.45 http://www.steeda.com/store/steeda-upper-control-arm-for-2005-and-up-ford-mustang.html Hopefully Alex will read this post and respond with opinion and advice. Is the BMR adjustable? This has to be a more common problem with the larger drive shafts especially if one upgrades the rear tires to something really sticky. Link to comment Share on other sites More sharing options...
drspa Posted September 27, 2010 Author Report Share Posted September 27, 2010 There seems to be a common denominator here, on the higher Hp Shelbys that have lowered suspension with a Aluminum driveshafts are having contact issues with the trans tunnel. I am glad and sorry at the same time that there is more than just myself who is having this problem. I have only had this car for 6 months and have had the speed shop in my area try to resolve this with-in the warranty. They re-torqued the suspension per Shelby's Tec guy and for a week or so it stopped. They sent new springs and bump stops, but I could not see that this would change a thing since these are the same parts that are only 6 month old. I like the thought process of the adjustable upper control arm, I am curious about the BMR kit as well. I will look into these fixes and am glad that I was able to get great advise. Thanks again John Link to comment Share on other sites More sharing options...
