relopez98 Posted September 14, 2010 Report Share Posted September 14, 2010 So this summer I washed and waxed her and inadvertantly got some wax and/or armoral on the black molding around the convertible top and around the air vents on the hood. I've tried windex and washing the hell out of them several times. I can't seem to get rid of the residue and it looks terrible in the sun. Any suggestions? Sorry no pics, but, I know I'm not the only one that's done this. Link to comment Share on other sites More sharing options...
skeet Posted September 14, 2010 Report Share Posted September 14, 2010 I use Armor All on the heat extractors to give them the like new look, so I don't think it is causing the problem. I usually do it after 3 washings. You may have gotten wax on them. You can try this, take an old toothbrush and spray some Armor All on it and work it into the areas with the white spots. It may also work with detailing spray and toothbrush. Link to comment Share on other sites More sharing options...
Imatk Posted September 14, 2010 Report Share Posted September 14, 2010 You used some wax that stains trim. If I were you I would get some wax/sealant that doesn't stain trim... there are many now so to use the ones that stain is just an unnecessary risk. You could try a product like Poorboy's Trim Restorer... it will help, but it may not get rid of the stain only cover it up. I've heard good things about Mr. Clean's Magic Eraser but I don't have first-hand experience with it. Link to comment Share on other sites More sharing options...
Son of GT Posted September 14, 2010 Report Share Posted September 14, 2010 Try using a clay bar to clean them up. Link to comment Share on other sites More sharing options...
texaggie Posted September 14, 2010 Report Share Posted September 14, 2010 +1 on the clay bar. The magic eraser definately cleans things, but I would think that it would be too harsh to use on the car. Link to comment Share on other sites More sharing options...
monsta Posted September 14, 2010 Report Share Posted September 14, 2010 I think that the clay bar is only going to break apart on the texture of the hood vents, I would try Mothers Back to Black ( or similar product ) with a SOFT tooth brush or just a microfiber applicator with a little bit of muscle. Link to comment Share on other sites More sharing options...
regalt87 Posted September 14, 2010 Report Share Posted September 14, 2010 You could try 3m wax and grease remover on a small test spot on the bottom of the lower valance where it doesn't show. If that doesn't harm it that used with a tooth brush should get it. The armor all and tooth brush will probably get it. I treat the black areas with pure silicone prior to waxing so that nothing sticks. Link to comment Share on other sites More sharing options...
BIKEBOY Posted September 14, 2010 Report Share Posted September 14, 2010 Try a small area of the non-toxic product called "oxy-clean" liquid and a toothbrush. My wife's co. makes and sells a ton of it under the Arm & Hammer name. I use the stuff on EVERYTHING. It smells pleasant, is totally biodegradable, and works on all tough stains. She carries an oxy-pen in her purse at all times for stains on clothes at the restaraunt! I cannot believe it took scientists all these years to create this seemingly natural harmless product? Good Luck. Link to comment Share on other sites More sharing options...
09 Red GT500 Posted September 15, 2010 Report Share Posted September 15, 2010 Replace your OEM vents with the True Forged hood vents. Problem solved... Link to comment Share on other sites More sharing options...
relopez98 Posted September 15, 2010 Author Report Share Posted September 15, 2010 Thanks everyone for the advice. I'll try it out this weekend. Where could I order the true forged hood vents. Back in 07 Shelby had them in stock but they seemed to disappear overnight. Link to comment Share on other sites More sharing options...
BIKEBOY Posted September 15, 2010 Report Share Posted September 15, 2010 Replace your OEM vents with the True Forged hood vents. Problem solved... Not so quick....IMHO the vent design matches really nothing else on the car??? Small holes??? Why not a honeycomb mesh??? Link to comment Share on other sites More sharing options...
SSSNAKE Posted September 15, 2010 Report Share Posted September 15, 2010 A lot of great advice here on how to fix your current problem, now I would reconmend you set aside your current wax and invest in a bottle of Turtle Wax Ice. No more white residue! (The lazy mans wax) great stuff. Link to comment Share on other sites More sharing options...
Kostas Posted September 15, 2010 Report Share Posted September 15, 2010 Try some WD40. It worked for me when i had wax on the vents and on the edges of the stripes. I stoped using paste wax because of that. Link to comment Share on other sites More sharing options...
janetatp Posted September 16, 2010 Report Share Posted September 16, 2010 So this summer I washed and waxed her and inadvertantly got some wax and/or armoral on the black molding around the convertible top and around the air vents on the hood. I've tried windex and washing the hell out of them several times. I can't seem to get rid of the residue and it looks terrible in the sun. Any suggestions? Sorry no pics, but, I know I'm not the only one that's done this. Works every time... Link to comment Share on other sites More sharing options...
SteelTownStang Posted September 16, 2010 Report Share Posted September 16, 2010 Works every time... +1... I've also had success with Mother's Black to Black. Link to comment Share on other sites More sharing options...
Lovin It Posted September 16, 2010 Report Share Posted September 16, 2010 So this summer I washed and waxed her and inadvertantly got some wax and/or armoral on the black molding around the convertible top and around the air vents on the hood. I've tried windex and washing the hell out of them several times. I can't seem to get rid of the residue and it looks terrible in the sun. Any suggestions? Sorry no pics, but, I know I'm not the only one that's done this. For black plastic trim (including textured) the product to fix your problem is "Color Magic" by Turtle Wax for black cars. It's actually a wax that contains black dye and pigment which works beautifully! I've been using this little trick since the 80's when I experimented with Kiwi black shoe polish paste on the moulding of my car. Either one will work for wax residue or fading. Link to comment Share on other sites More sharing options...
springer Posted September 16, 2010 Report Share Posted September 16, 2010 Lovin' It, I've been using the black shoe polish trick myself for many years. Works great on black trim. Link to comment Share on other sites More sharing options...
relopez98 Posted September 16, 2010 Author Report Share Posted September 16, 2010 Wow! You guys are life savers. Now, just to figure out which route to take... Armorall and toothbrush back to black color magic Trim detailer shoe polish.... lots of choices. I love this site! Link to comment Share on other sites More sharing options...
mustang loco Posted September 16, 2010 Report Share Posted September 16, 2010 You could always give this trick a try also,whenever I'm polishing or waxing cars,I use "painters edging tape" on all black moldings...after your done,tape "off" and no residue anywhere!! Link to comment Share on other sites More sharing options...
Lovin It Posted September 17, 2010 Report Share Posted September 17, 2010 You could always give this trick a try also,whenever I'm polishing or waxing cars,I use "painters edging tape" on all black moldings...after your done,tape "off" and no residue anywhere!! +1 on the painter's tape! Can be used to shield your stripes while waxing. Link to comment Share on other sites More sharing options...
08 Mustang Posted September 17, 2010 Report Share Posted September 17, 2010 I use turtle wax ice on my black molding pieces.. Link to comment Share on other sites More sharing options...
mustang loco Posted September 18, 2010 Report Share Posted September 18, 2010 +1 on the painter's tape! Can be used to shield your stripes while waxing. +1, Ido the same!! I use turtle wax ice on my black molding pieces.. Use it too for a finishinhg touch!! Works great. Link to comment Share on other sites More sharing options...
dsublett Posted September 19, 2010 Report Share Posted September 19, 2010 I've used Back to Black, Meguairs Trim Detailer, and Turtle Wax Ice on the black trim and all seemed to do a good job. I agree that Ice is easy to use, working well on the paint and the trim. Link to comment Share on other sites More sharing options...
cobra 07 Posted September 20, 2010 Report Share Posted September 20, 2010 Sounds dum - but peanut butter wor ks Link to comment Share on other sites More sharing options...
relopez98 Posted September 20, 2010 Author Report Share Posted September 20, 2010 Tried armorall and toothbrush. Worked like a charm. Vents have never looked so cherry! Did the trim all around the top as well and it looks damn good. Need to upload some pics. Link to comment Share on other sites More sharing options...
