SHELBYGT698 Posted September 10, 2010 Report Share Posted September 10, 2010 Numrous SGT owners has mentioned camber bolts are to replace the lower strut bolt? I just received my Eibach camber bolts, the limited instructions on the box tells me to replace the uppers? What is the real way? Link to comment Share on other sites More sharing options...
FordRocks1 Posted September 10, 2010 Report Share Posted September 10, 2010 I have not had mine installed yet, waiting on all new tires but it seems like the top bolt. http://www.hrsprings.com/products/triple-c/ Link to comment Share on other sites More sharing options...
motorjock205 Posted September 11, 2010 Report Share Posted September 11, 2010 I used the Ingall's bolts and installed one in each lower strut mount...brought the alignment in just right for daily driving. Link to comment Share on other sites More sharing options...
SicShelby Posted September 12, 2010 Report Share Posted September 12, 2010 I replaced the lower bolts. Link to comment Share on other sites More sharing options...
SHELBYGT698 Posted September 13, 2010 Author Report Share Posted September 13, 2010 I replaced the lower bolts. Does it matter which bolt you replaced? I see it done both ways. I'll just follow the limited instruction on the Eibach box I suposed unless someone can tell me differently. Link to comment Share on other sites More sharing options...
SMGT Posted September 13, 2010 Report Share Posted September 13, 2010 Does it matter which bolt you replaced? I see it done both ways. I'll just follow the limited instruction on the Eibach box I suposed unless someone can tell me differently. According to an email from a tech at Ingalls and the instructions that came with my bolts if using one bolt per side it is the upper. Not sure why. See attached. Ingalls Cam Bolt Instructions.pdf Ingalls Cam Bolt Instructions.pdf Link to comment Share on other sites More sharing options...
