Venom4U Posted September 8, 2010 Report Share Posted September 8, 2010 I'm debating on ordering this option. Can anyone tell me if it would be beneficial to order this? I was recently at a car show and someone had a 2008 GT500 he informed me that a high performance cooling system is a must. Any advice will be appreciated. Thanks. Link to comment Share on other sites More sharing options...
DubbsFaris Posted September 8, 2010 Report Share Posted September 8, 2010 You were told right Venom. You live in a region that gets fairly hot, and even at 60 degrees, heat soak is a problem. If you order the supercharged GT350, you should go with the cooling package, or your car's supercharger will be putting out half power within two or three laps. If you dont drag or track, then it is a waste of money. No heat soak at car shows. Link to comment Share on other sites More sharing options...
clark17357 Posted September 8, 2010 Report Share Posted September 8, 2010 It is a great investment. I noticed the difference big time and I have only the 4.6 motor, which puts out less heat than the monster motor you have in your car. Jim Link to comment Share on other sites More sharing options...
Venom4U Posted September 8, 2010 Author Report Share Posted September 8, 2010 You were told right Venom. You live in a region that gets fairly hot, and even at 60 degrees, heat soak is a problem. If you order the supercharged GT350, you should go with the cooling package, or your car's supercharger will be putting out half power within two or three laps. If you dont drag or track, then it is a waste of money. No heat soak at car shows. That s exactly how I will be using this car for shows but I still might take it 300 or 400 miles up the road for an extended run. Of course abiding by the laws of the road. :rolleyes: It gets hot in South Florida even in the wintertime. I might have to take the dive and fork over some cash for this one. Link to comment Share on other sites More sharing options...
clark17357 Posted September 8, 2010 Report Share Posted September 8, 2010 Well, if the whole truth be told, the set up looks really cool, particularly if you get the tanks. Got for it. Jim Link to comment Share on other sites More sharing options...
tony356 Posted September 9, 2010 Report Share Posted September 9, 2010 You were told right Venom. You live in a region that gets fairly hot, and even at 60 degrees, heat soak is a problem. If you order the supercharged GT350, you should go with the cooling package, or your car's supercharger will be putting out half power within two or three laps. If you dont drag or track, then it is a waste of money. No heat soak at car shows. I am getting one if they ever start sending completed units to Shelby or might just have my local wrench add it like I did with my gt500 but I'd get it brotha. Link to comment Share on other sites More sharing options...
