ahdoman Posted August 27, 2010 Report Share Posted August 27, 2010 A PO kind of botched the assembly on my front end. I took it apart to fix a fan that wasn't working. I Just want to make sure on this; the cooling fans are sandwiched between the radiator and condensor. Correct? If so, are the fans bolted to the radiator or is there a bracket that holds the fan assembly to the front end? Link to comment Share on other sites More sharing options...
shelbymotorsports Posted August 27, 2010 Report Share Posted August 27, 2010 A PO kind of botched the assembly on my front end. I took it apart to fix a fan that wasn't working. I Just want to make sure on this; the cooling fans are sandwiched between the radiator and condensor. Correct? If so, are the fans bolted to the radiator or is there a bracket that holds the fan assembly to the front end? Yes the fans go in between the radiator and the a/c condensor. The fan assembly is connected to the radiator by four screws. Steve Link to comment Share on other sites More sharing options...
