Jer Posted August 7, 2010 Report Share Posted August 7, 2010 My car's out having the scoop, stripes, mufflers, hood pins, etc... done. When I get it back, I want to swap out the hood pin plates for the billet ones, but I'm not looking forward to putting stainless screws back into my "iron-decontaminated" and repainted hood. Can anyone lead me to the source and part number for the right size aluminum screws? I've tried searching the forum, no luck. I know it'll be -most likely- available from a marine parts house, etc... but I figured someone here might have the insider info already.... or maybe bought a box of 100 and used 8, stuck with leftovers I can buy... Jer Link to comment Share on other sites More sharing options...
bruces Posted August 8, 2010 Report Share Posted August 8, 2010 I would be interested also no problem yet but this should not be happening I need same info type and where did you buy all I can find is stainless Bruce call if you like Bruce Global 1-800-558-1811 Link to comment Share on other sites More sharing options...
aonebadbone Posted August 8, 2010 Report Share Posted August 8, 2010 I have never seen screws made from aluminum so good luck finding any. You could use aluminum pop rivets or they also make aluminum rivets but you need a rivet set to use them and another guy to help you. Link to comment Share on other sites More sharing options...
Jer Posted August 8, 2010 Author Report Share Posted August 8, 2010 I have never seen screws made from aluminum so good luck finding any. You could use aluminum pop rivets or they also make aluminum rivets but you need a rivet set to use them and another guy to help you. They exist, they are in use in many marine applications.... Just type "aluminum screw" into a Google search. I just figured someone already had the specs, a good supplier, and/or extras. Jer I attached the image below to show an example: Link to comment Share on other sites More sharing options...
