Dennis Brown Posted August 5, 2010 Report Share Posted August 5, 2010 UPS brouth mine yesterday I will post some pics after I get them on. Link to comment Share on other sites More sharing options...
belltr Posted August 5, 2010 Report Share Posted August 5, 2010 Thanks for the info and pics! BTW, where did you get that Cobra emblem for the blower? That's a nice touch. I found them here... http://www.latemodelrestoration.com/item/LRS-1447A/99-01-Mustang-Cobra-Intake-Plaque Link to comment Share on other sites More sharing options...
09KR0058 Posted August 5, 2010 Report Share Posted August 5, 2010 I found them here... http://www.latemodel...a-Intake-Plaque Thanks for the link! Link to comment Share on other sites More sharing options...
belltr Posted August 5, 2010 Report Share Posted August 5, 2010 Thanks for the link! Anything for a fellow SHELBY owner especially in the best color… Link to comment Share on other sites More sharing options...
wjlane Posted August 5, 2010 Report Share Posted August 5, 2010 09KR0058, Man I dropped the ball on getting you a link. I just assumed they were easy to find at any Stang parts store. Sorry for not getting back to you! Link to comment Share on other sites More sharing options...
wjlane Posted August 5, 2010 Report Share Posted August 5, 2010 Anything for a fellow SHELBY owner especially in the best color… Well, if red is the best color, why did Ford only make the intake plaques in blue? Link to comment Share on other sites More sharing options...
09KR0058 Posted August 5, 2010 Report Share Posted August 5, 2010 09KR0058, Man I dropped the ball on getting you a link. I just assumed they were easy to find at any Stang parts store. Sorry for not getting back to you! No problem. Its all good! Link to comment Share on other sites More sharing options...
Dennis Brown Posted August 6, 2010 Report Share Posted August 6, 2010 So what's involved with installing these? Looks like just two screws/bolts? Any specific torque number to put them on? Any problems with taking the old ones off? Do we need some kind of gasket to install the new ones? And as Scotty said above, if the driver's side is mostly covered by the plumbing (which doesn't really bother me), how difficult will it be to get the old one off and the new one on? Thanks There is a torx bolt that is a 3mm or a 3.5mm in the front of the cover on the passanger side and you will need a 10mm deep well socket for the back bolt on the passanger side. On the driver side you will need the same torx for both bolts. You will have to take off the air intake tube you will need a 10mm wrench to remove the air breather from the air box and a flat head screw drive to remove the air intake tube. It took less than a hour to put them on. The look good but you do not see much on the driver side. Link to comment Share on other sites More sharing options...
belltr Posted August 6, 2010 Report Share Posted August 6, 2010 Well, if red is the best color, why did Ford only make the intake plaques in blue? I'm have been looking at these for awhile; they are fender emblems (RED)but should be adhesive backed and not the old style with the point that goes into the fender and held on by a metal cap... which should mount on the blower with no problem, although I am not sure what might happen when it gets hot... http://www.cjponyparts.com/product.asp?pn=EMC13P&utm_source=google&utm_medium=merchant&utm_campaign=shopping&bhcd2=1281063590 Link to comment Share on other sites More sharing options...
wjlane Posted August 6, 2010 Report Share Posted August 6, 2010 I'm not sure what type of adhesive they use on the blue intake plaque but it was specifically meant to withstand high temperatures. I see your concern with the red snake though. Last thing you want is that adhesive drying up from the heat, then the snake falls off. Why not just buy a blue emblem, then paint over the blue with high-temp red paint using a fine tipped brush? It would be worth a shot since they are only $12. Besides, you'd gain 50rwhp with the BLUE cobra plaque vs. 20rwhp for the red snakes! Link to comment Share on other sites More sharing options...
belltr Posted August 6, 2010 Report Share Posted August 6, 2010 I'm not sure what type of adhesive they use on the blue intake plaque but it was specifically meant to withstand high temperatures. I see your concern with the red snake though. Last thing you want is that adhesive drying up from the heat, then the snake falls off. Why not just buy a blue emblem, then paint over the blue with high-temp red paint using a fine tipped brush? It would be worth a shot since they are only $12. Besides, you'd gain 50rwhp with the BLUE cobra plaque vs. 20rwhp for the red snakes! I just might have to do that... I am going to try and find a touch up pen in red and outline the SHELBY on the Strut tower brace, I think that will look nice Link to comment Share on other sites More sharing options...
09KR0058 Posted August 6, 2010 Report Share Posted August 6, 2010 There is a torx bolt that is a 3mm or a 3.5mm in the front of the cover on the passanger side and you will need a 10mm deep well socket for the back bolt on the passanger side. On the driver side you will need the same torx for both bolts. You will have to take off the air intake tube you will need a 10mm wrench to remove the air breather from the air box and a flat head screw drive to remove the air intake tube. It took less than a hour to put them on. The look good but you do not see much on the driver side. Thanks! That's just the kind of info I was looking for. Just got off the phone with Justin at SPP and ordered my red covers. Will try to remember to take some pictures when I do the swap-out. I love this forum! Link to comment Share on other sites More sharing options...
wjlane Posted August 6, 2010 Report Share Posted August 6, 2010 Thanks! That's just the kind of info I was looking for. Just got off the phone with Justin at SPP and ordered my red covers. Will try to remember to take some pictures when I do the swap-out. I love this forum! Remember to be careful with your tools when installing the new covers as they will get dinged up VERY easily if you are careless. Link to comment Share on other sites More sharing options...
09KR0058 Posted August 6, 2010 Report Share Posted August 6, 2010 Remember to be careful with your tools when installing the new covers as they will get dinged up VERY easily if you are careless. Absolutely. I will be in full "Anal Retentive" mode! Link to comment Share on other sites More sharing options...
09KR0058 Posted August 19, 2010 Report Share Posted August 19, 2010 Got home Tuesday night and these babies were sitting on my front steps: Don't know why the picture (from my iPhone 4) shows so much yellow. Its actually all silver/red. Got some great detailed instructions from dennis429 above, but still don't know what the torque numbers should be for the bolts. Does anyone know? Thanks Link to comment Share on other sites More sharing options...
09KR0058 Posted August 21, 2010 Report Share Posted August 21, 2010 I called the manufacturer today. Their address and phone number are on the shipping label. The lady I spoke with and the guy who runs the machine that makes them were really great to talk to. He told me that they have similar covers on a GT500 at their shop. He said to not worry about torque. Just use a dab of blue Loctite 242 and snug them down. I'm going to do this now and will post pictures when done. BTW, they mentioned that they are in talks with Shelby for some future projects. I was chomping at the bit to find out what's going to be coming, but he wouldn't say. MUST HAVE MORE BLING!!!!!!!! Link to comment Share on other sites More sharing options...
Mustang_Scotty Posted August 21, 2010 Report Share Posted August 21, 2010 Hopefully, have more bling that we can see! I called the manufacturer today. Their address and phone number are on the shipping label. The lady I spoke with and the guy who runs the machine that makes them were really great to talk to. He told me that they have similar covers on a GT500 at their shop. He said to not worry about torque. Just use a dab of blue Loctite 242 and snug them down. I'm going to do this now and will post pictures when done. BTW, they mentioned that they are in talks with Shelby for some future projects. I was chomping at the bit to find out what's going to be coming, but he wouldn't say. MUST HAVE MORE BLING!!!!!!!! Link to comment Share on other sites More sharing options...
09KR0058 Posted August 30, 2010 Report Share Posted August 30, 2010 Finally got these babys on. Dont' really care that you can't see much of the cover on the driver's side. I know its there!!! The install went real easy . Only took about 45 min. Link to comment Share on other sites More sharing options...
frknfast Posted September 19, 2010 Report Share Posted September 19, 2010 Rec'd my black covers yestaerday. Put them on last night. Too dark for pics. Anyways these are wroks of art and Jake again has done an excelent job!!! He did the covers and engine caps for my 08GT500 and my Ford GT. His work is fantasttic and his customer service is even better. Thks Jank!! Keep up the good work!! ( say hi to Sam) Link to comment Share on other sites More sharing options...
project321 Posted September 25, 2010 Report Share Posted September 25, 2010 Rec'd my black covers yestaerday. Put them on last night. Too dark for pics. Anyways these are wroks of art and Jake again has done an excelent job!!! He did the covers and engine caps for my 08GT500 and my Ford GT. His work is fantasttic and his customer service is even better. Thks Jank!! Keep up the good work!! ( say hi to Sam) Frknfast, Thanks so much for the compliments and your support over the years. We feel lucky to be able to make parts like these for true car enthusiasts that appreciate our work. Especially in an economy like this. Thank you! Jake Project321 P.S. Sam says hello! Link to comment Share on other sites More sharing options...
09KR0058 Posted September 27, 2010 Report Share Posted September 27, 2010 Frknfast, Thanks so much for the compliments and your support over the years. We feel lucky to be able to make parts like these for true car enthusiasts that appreciate our work. Especially in an economy like this. Thank you! Jake Project321 P.S. Sam says hello! Hey Jake, thanks again from me also. The people I've shown mine to are just blown away, as I am, how great these look! So what else should we be looking forward to from you gyys? John Link to comment Share on other sites More sharing options...
project321 Posted September 28, 2010 Report Share Posted September 28, 2010 Hey Jake, thanks again from me also. The people I've shown mine to are just blown away, as I am, how great these look! So what else should we be looking forward to from you gyys? John John, Your welcome and thank you! We have been talking Robert about a few things but I wouldn't want to get specific before we know for sure. I can tell you that we'll have more for your GT500 soon! Again, Thank you for your support! Link to comment Share on other sites More sharing options...
