txlaw Posted February 4, 2007 Report Share Posted February 4, 2007 Yesterday under hard acceleration when shifting to second with some wheel hop a loud pop came from the rear. No apparent damage or change in handling. Everything is stock so all noises are courtesy of Ford. Anyone else? Any ideas? Link to comment Share on other sites More sharing options...
1badsho Posted February 4, 2007 Report Share Posted February 4, 2007 Yesterday under hard acceleration when shifting to second with some wheel hop a loud pop came from the rear. No apparent damage or change in handling. Everything is stock so all noises are courtesy of Ford. Anyone else? Any ideas? I would keep a eye on it .. but its possible its the dreaded wheel hop. I would also take a look see underneath just to see if u can see anything that doesnt look right ... just as a precaution dond Link to comment Share on other sites More sharing options...
FormerGmc Posted February 4, 2007 Report Share Posted February 4, 2007 Yesterday under hard acceleration when shifting to second with some wheel hop a loud pop came from the rear. No apparent damage or change in handling. Everything is stock so all noises are courtesy of Ford. Anyone else? Any ideas? Yep! Mine has done it. First time it freaked me out. I think its wheel hop. Link to comment Share on other sites More sharing options...
Marc@Kentucky Posted February 4, 2007 Report Share Posted February 4, 2007 I've had it happen twice, both times when hard shifting into 2nd. 1st time I thought it was my seat track breaking. Second time it sounded like the driveshaft hit the floorpan. Link to comment Share on other sites More sharing options...
07 GT500 Posted February 4, 2007 Report Share Posted February 4, 2007 I've had it happen twice, both times when hard shifting into 2nd. 1st time I thought it was my seat track breaking. Second time it sounded like the driveshaft hit the floorpan. Yeah, I've heard it on mine before also,,,coming out of first into second. Not good.....Hopefully I won't hear it anymore after my new BMR upper and lower control arms get here and I install them. Link to comment Share on other sites More sharing options...
mikspny Posted February 5, 2007 Report Share Posted February 5, 2007 Gosh...I feel so boring and useless...this has not happened to me at all or any variation there of. Link to comment Share on other sites More sharing options...
FordGeek Posted February 5, 2007 Report Share Posted February 5, 2007 Sounds like suspension bind to me caused by the Shelby's wheel hop. You're basically fully compressing your suspension components under hard acceleration causing a "pop" as they bottom out. If you don't let up while experiencing moderate to severe wheel hop, you will screw up your pinion bearing and, if the shaking is crazy enough, you can potentially break the yolk; something that is especially easy to do with the less than stellar two piece units mustangs come with. Regards, FordGeek (Joseph) Link to comment Share on other sites More sharing options...
