BLOWN Posted July 18, 2010 Report Share Posted July 18, 2010 I got a problem. A while back ago me and my 6 year old grandson put the blower motor together and know I thnk we might have messed up.How are we goin g to get the engne in the car wth out breaking a ear off the manifold or gouging somethng.Will I need to take the manifold off or will I need to take the manifold &heads off I hope not. There is NO way a plate bolted to the manifold would work.Thanks Link to comment Share on other sites More sharing options...
dave40th Posted July 18, 2010 Report Share Posted July 18, 2010 I have used the tapped bolt holes in the front and back of the heads, I use a nylon washer against the head so it doesn't get scrached. Hope this helps. Dave Link to comment Share on other sites More sharing options...
kahmann Posted July 19, 2010 Report Share Posted July 19, 2010 I have used the tapped bolt holes in the front and back of the heads, I use a nylon washer against the head so it doesn't get scrached. Hope this helps. Dave Exactly what I would do. I've done this with success, as well. Although I definitely prefer to use a manifold mounted engine lifting plate, whenever possible. A nylon washer at each bolt will help to protect the head from the bolts themselves. But make sure to wrap the chain with a towel or something so that you don't scratch up the side of the heads as you're lowering it in. Ken EDIT: That's a sharp looking build you've got, by the way! The Performer RPM heads are a nice choice - I had them in my 331 stroker 66 fastback and they helped make a ton of power. Link to comment Share on other sites More sharing options...
svttim Posted July 19, 2010 Report Share Posted July 19, 2010 We have used exhaust maifilds bolt holes as well Link to comment Share on other sites More sharing options...
BLOWN Posted July 19, 2010 Author Report Share Posted July 19, 2010 Thanks..If I use the back of the heads or the Exh manifold bolt holes they are not going to strip out or pull out or somethng weird are they? just a little worrie about that. Link to comment Share on other sites More sharing options...
SGT/SC#0471 Posted February 23, 2011 Report Share Posted February 23, 2011 Personally I would skip the exhaust bolts. Link to comment Share on other sites More sharing options...
David Hawkins Posted March 7, 2011 Report Share Posted March 7, 2011 I have used the tapped bolt holes in the front and back of the heads, I use a nylon washer against the head so it doesn't get scrached. Hope this helps. Dave What He Said ^^^^^ You can also find the Lifting Plats that the Factory Used and install those. Link to comment Share on other sites More sharing options...
BLOWN Posted June 26, 2011 Author Report Share Posted June 26, 2011 What He Said ^^^^^ You can also find the Lifting Plats that the Factory Used and install those. Will the lifting plates bolt to the supercharger Manifold or will I need to take it off? Link to comment Share on other sites More sharing options...
