obnoxioushook Posted July 4, 2010 Report Share Posted July 4, 2010 Has anyone else ever heard a bang coming from the left side in the engine compartment. Only does it once and seems to happen after car is started. Heard it a couple of times when driving. Sounds like somethging hitting the car. 2008 gt500 Link to comment Share on other sites More sharing options...
mystang68/05 Posted July 4, 2010 Report Share Posted July 4, 2010 Mine does it when it is restarted after warmed up. Feels like under my left foot with the clutch peddle depressed. Link to comment Share on other sites More sharing options...
SC5.4 Posted July 4, 2010 Report Share Posted July 4, 2010 You could be hearing the AC control door inside of dash. Try turning the AC off before you start it a few times and see if it makes a difference. Mine will do it every once in a while after it sits. Link to comment Share on other sites More sharing options...
Slabo Posted July 4, 2010 Report Share Posted July 4, 2010 You could be hearing the AC control door inside of dash. Try turning the AC off before you start it a few times and see if it makes a difference. Mine will do it every once in a while after it sits. +1 I was also thinking the AC either the clutch engaging or the control door as mentioned. Link to comment Share on other sites More sharing options...
REDTAIL Posted July 4, 2010 Report Share Posted July 4, 2010 +1 I was also thinking the AC either the clutch engaging or the control door as mentioned. +2 on the AC Link to comment Share on other sites More sharing options...
