tko211 Posted June 4, 2010 Report Share Posted June 4, 2010 I know some of you have the Shelby lower grill that goes in the lower middle section of the front bumper... My question is what is the best method to install this part and what tips or tricks should I be aware of when doing mine? Link to comment Share on other sites More sharing options...
rush_junky Posted June 4, 2010 Report Share Posted June 4, 2010 I know some of you have the Shelby lower grill that goes in the lower middle section of the front bumper... My question is what is the best method to install this part and what tips or tricks should I be aware of when doing mine? It's a pain to hold it in place for marking and drilling. It's best to have another person hold it in place while you mark and/or drill. Use a string and pull to hold it flush while you mark/drill. Once the holes are drilled, use rivets. The existing holes are worthless if I recall correctly. GOOD LUCK ! Link to comment Share on other sites More sharing options...
JeffIsHereToo Posted June 4, 2010 Report Share Posted June 4, 2010 I know some of you have the Shelby lower grill that goes in the lower middle section of the front bumper... My question is what is the best method to install this part and what tips or tricks should I be aware of when doing mine? See here: http://www.teamshelby.com/forums/index.php?/topic/25352-gtcs-lower-black-grill-installation/page__p__375005__hl__grill__fromsearch__1entry375005 Link to comment Share on other sites More sharing options...
tko211 Posted June 4, 2010 Author Report Share Posted June 4, 2010 Super helpful! Thanks... Now off to go get some rivets. Link to comment Share on other sites More sharing options...
Larry T Posted June 5, 2010 Report Share Posted June 5, 2010 Super helpful! Thanks... Now off to go get some rivets. Use stainless steel ones and install should take about 20 mins Link to comment Share on other sites More sharing options...
gth0007 Posted June 5, 2010 Report Share Posted June 5, 2010 I know some of you have the Shelby lower grill that goes in the lower middle section of the front bumper... My question is what is the best method to install this part and what tips or tricks should I be aware of when doing mine? The last two lower grills I've installed used Hex Head Screws with nuts, not Rivets. I would think the rivets would be harder to do and a bit of a pain if you ever had to remove the assembly (repainting lower facia for example). just a thought. Link to comment Share on other sites More sharing options...
kahmann Posted June 5, 2010 Report Share Posted June 5, 2010 ^Rivets suck. I used the bolts that came with the Shelby brake cooling duct bezels to secure the lower grill. Worked like a champ. That space is tight enough to work in with an allen key and micro box wrench. I can't imagine trying to fight with a rivet gun under there. Link to comment Share on other sites More sharing options...
