CobraKaz Posted June 2, 2010 Report Share Posted June 2, 2010 What are the differences in % between both dyno's ? The car made 480 RWHP before mods but next time its going on a Mustang Dyno . Link to comment Share on other sites More sharing options...
10random Posted June 2, 2010 Report Share Posted June 2, 2010 Usually 10-15%, but keep in mind it can vary with the Mustang dyno, since the load settings are variable. Link to comment Share on other sites More sharing options...
CobraKaz Posted June 2, 2010 Author Report Share Posted June 2, 2010 Usually 10-15%, but keep in mind it can vary with the Mustang dyno, since the load settings are variable. Is there any way the average person as myself , would knowif the load settings are wrong ? What are load settings ? Link to comment Share on other sites More sharing options...
i8acobra Posted June 2, 2010 Report Share Posted June 2, 2010 Just ask the dyno operator to make sure he has your curb weight and gear ratio entered into the computer correctly. Mustang Dynos need that info to be accurate. Link to comment Share on other sites More sharing options...
Torched10 Posted June 2, 2010 Report Share Posted June 2, 2010 Just ask the dyno operator to make sure he has your curb weight and gear ratio entered into the computer correctly. Mustang Dynos need that info to be accurate. what is the curb weight?/--is that the GWVR number on the plate in the door?? Link to comment Share on other sites More sharing options...
mullens Posted June 2, 2010 Report Share Posted June 2, 2010 Curb weight is what the car weighs sans driver. I think GWVR is what it's rated at loaded. Link to comment Share on other sites More sharing options...
CobraKaz Posted June 2, 2010 Author Report Share Posted June 2, 2010 Just ask the dyno operator to make sure he has your curb weight and gear ratio entered into the computer correctly. Mustang Dynos need that info to be accurate. So thats approx 4000 lbs for the weight and 3.55 for the rear end . Does th weight have to be exact ? Link to comment Share on other sites More sharing options...
GOTVENOMGT500 Posted June 2, 2010 Report Share Posted June 2, 2010 For the 2011 GT500 Coupe I have read weights being from 3790 to 3820. The 4000 is a bit on the heavy side, did you read that in the door plate, think before the aluminum blocked 2011 the 2010 was in the 3900 lb area or so. Link to comment Share on other sites More sharing options...
CobraKaz Posted June 2, 2010 Author Report Share Posted June 2, 2010 For the 2011 GT500 Coupe I have read weights being from 3790 to 3820. The 4000 is a bit on the heavy side, did you read that in the door plate, think before the aluminum blocked 2011 the 2010 was in the 3900 lb area or so. Ho , just a guess . Not really that far off though if 3900 is the number . Link to comment Share on other sites More sharing options...
