et10sec Posted May 27, 2010 Report Share Posted May 27, 2010 question, getting ready to paint the side of of hertz car, the side air scoops, are they installed with two face tape or bolts, also the scoops on the hood, there is 3 revets, is that waht holds them on or is that tape. thanks ed z #297 Quote Link to comment Share on other sites More sharing options...
gene64cobra Posted May 27, 2010 Report Share Posted May 27, 2010 question, getting ready to paint the side of of hertz car, the side air scoops, are they installed with two face tape or bolts, also the scoops on the hood, there is 3 revets, is that waht holds them on or is that tape. thanks ed z #297 i don't know about the side scoops, but the hood is reveted as well i believe with two face tape. Quote Link to comment Share on other sites More sharing options...
SteelTownStang Posted May 27, 2010 Report Share Posted May 27, 2010 question, getting ready to paint the side of of hertz car, the side air scoops, are they installed with two face tape or bolts, also the scoops on the hood, there is 3 revets, is that waht holds them on or is that tape. thanks ed z #297 Neighbor... The OEM side scoops are held in place by plastic push pins and 3M automotive tape. Not sure about the hood scoop, but on my 07 GT the hood scoop was attached with bolts and 3M tape. If you pull the insulation back from under the hood you will be able to see how it's attached... Actually, you may not even have to pull the insulation back... the hardware may be visual... it was on mine... Quote Link to comment Share on other sites More sharing options...
et10sec Posted May 27, 2010 Author Report Share Posted May 27, 2010 Neighbor... The OEM side scoops are held in place by plastic push pins and 3M automotive tape. Not sure about the hood scoop, but on my 07 GT the hood scoop was attached with bolts and 3M tape. If you pull the insulation back from under the hood you will be able to see how it's attached... Actually, you may not even have to pull the insulation back... the hardware may be visual... it was on mine... thank you, with the plastic push pins, how would you get them off with out brakeing the pins? thanks neighbor Quote Link to comment Share on other sites More sharing options...
SteelTownStang Posted May 27, 2010 Report Share Posted May 27, 2010 thank you, with the plastic push pins, how would you get them off with out brakeing the pins? thanks neighbor They are the ribbed pins... you shouldn't have any problems removing them. I believe that there are only two per panel that are located near the top and bottom. I would suggect using fishing line... 10-20lbs, to cut through the tape, then just pull... Quote Link to comment Share on other sites More sharing options...
et10sec Posted May 27, 2010 Author Report Share Posted May 27, 2010 They are the ribbed pins... you shouldn't have any problems removing them. I believe that there are only two per panel that are located near the top and bottom. I would suggect using fishing line... 10-20lbs, to cut through the tape, then just pull... thanks . steeltownstang, i will see you at a cruise this summer. #297 hertz ed zeliesko Quote Link to comment Share on other sites More sharing options...
Larry T Posted May 27, 2010 Report Share Posted May 27, 2010 thanks . steeltownstang, i will see you at a cruise this summer. #297 hertz ed zeliesko Just wondering if it's a Hertz GT-H it should not have a hood scoop. Those are specifice to the Shelby GT :huh: Quote Link to comment Share on other sites More sharing options...
et10sec Posted May 27, 2010 Author Report Share Posted May 27, 2010 Just wondering if it's a Hertz GT-H it should not have a hood scoop. Those are specifice to the Shelby GT no hood scoop, there is a riveted air induction vent, is the rivets show, or do they hold the induction piece on :huh: Quote Link to comment Share on other sites More sharing options...
Larry T Posted May 27, 2010 Report Share Posted May 27, 2010 I beleive that the rivets are what holds this piece on, it is non functional and is sold thru the Shelby Store, I have attached a link so maybe give them a call and see what it comes with and you will have a better idea. http://www.shelbystore.com/product-p/cs6-011.htm Hope this helps Quote Link to comment Share on other sites More sharing options...
SteelTownStang Posted May 27, 2010 Report Share Posted May 27, 2010 thanks . steeltownstang, i will see you at a cruise this summer. #297 hertz ed zeliesko Sounds good Quote Link to comment Share on other sites More sharing options...
i8acobra Posted May 28, 2010 Report Share Posted May 28, 2010 Mine doesn't have any rivets, just round dots that look like rivets. It's all tape. Quote Link to comment Share on other sites More sharing options...
