Venom4U Posted May 20, 2010 Report Share Posted May 20, 2010 Can you please provide me with more info on this? 1) Is the additional charge for the blue strips only or does this include a special white paint also? 2) How many layers of clear coat will be applied to the vehicle? Thanks for the help. Link to comment Share on other sites More sharing options...
RogerS Posted May 21, 2010 Report Share Posted May 21, 2010 Can you please provide me with more info on this? 1) Is the additional charge for the blue strips only or does this include a special white paint also? 2) How many layers of clear coat will be applied to the vehicle? Thanks for the help. Standard is Vinyl striping. Addition charge for side and over the top painted, correct Guardsman Blue strips and 2 coats of clear. Hope this helps. Link to comment Share on other sites More sharing options...
SGT/SC#0471 Posted May 21, 2010 Report Share Posted May 21, 2010 How much is the charge? And will you guys be doing SGT's as well if brought back down? Link to comment Share on other sites More sharing options...
Venom4U Posted May 21, 2010 Author Report Share Posted May 21, 2010 Standard is Vinyl striping. Addition charge for side and over the top painted, correct Guardsman Blue strips and 2 coats of clear. Hope this helps. Thanks Roger , So this does not include any white paint. Just the blue stripes. Is the clear coat just for the stripes? Or the whole car? Link to comment Share on other sites More sharing options...
RogerS Posted May 21, 2010 Report Share Posted May 21, 2010 Thanks Roger , So this does not include any white paint. Just the blue stripes. Is the clear coat just for the stripes? Or the whole car? Clear is for the stripe and small overlap. Remembering back to the original in 65, the cars were painted white from Ford then sent for conversion. The side stripe was painted and the G.T.350 was tape. Most were were not striped at the factory. It was a dealer installed option. Just a hard tape line you could feel as you ran your hand over the stripe to the white paint. It has a similar feel but smoother. Hope this helps. Roger Link to comment Share on other sites More sharing options...
RogerS Posted May 21, 2010 Report Share Posted May 21, 2010 How much is the charge? And will you guys be doing SGT's as well if brought back down? $4.500 and no. Roger Link to comment Share on other sites More sharing options...
Venom4U Posted May 21, 2010 Author Report Share Posted May 21, 2010 Clear is for the stripe and small overlap. Remembering back to the original in 65, the cars were painted white from Ford then sent for conversion. The side stripe was painted and the G.T.350 was tape. Most were were not striped at the factory. It was a dealer installed option. Just a hard tape line you could feel as you ran your hand over the stripe to the white paint. It has a similar feel but smoother. Hope this helps. Roger Thanks Roger, I should have my ID # for you in about 10 days (says my dealer). I’m still tossing around the painted stripes. Link to comment Share on other sites More sharing options...
RogerS Posted May 21, 2010 Report Share Posted May 21, 2010 Thanks Roger, I should have my ID # for you in about 10 days (says my dealer). I’m still tossing around the painted stripes. Excellent. Link to comment Share on other sites More sharing options...
SGT/SC#0471 Posted May 23, 2010 Report Share Posted May 23, 2010 $4.500 and no. Roger Ouch and Doh! Link to comment Share on other sites More sharing options...
